rublet Lifetime Member
Posted: Tue Oct 21, 2008 10:31 pm Post subject: removed cameras still on map |
hi guys,
Just a query regarding speed cameras that have been removed on the submitting page (big red cross and greyed out) they seem to be still on the latest update for instance, camera id TEMP:40090@40.
Should it still be visible on the map? and if so for how long because it has obviously been taken away so in my view should not be there.
cheers |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Tue Oct 21, 2008 10:42 pm Post subject: |
There was no TEMP file in the last release of the database. You're still looking at an old copy of that file. |
GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Wed Oct 22, 2008 12:12 am Post subject: |
Generally speaking, if a category contains no cameras, an empty folder is included so that users can simply overwrite their existing data.
However, as of 8 Oct 2008, the TEMP cameras were changed:
Quote: | Version 6.102 - 08 OCT 08
This release sees 152 static and mobile speed cameras added/modified across the various speed camera databases by 81 users. Please keep submitting all sightings of mobile speed cameras so we can keep our database up to date with active sites. Apparently-inactive sites are regularly removed from the database.
This release also sees a major change in the way that Temporary Cameras are handled. Previously all temporary Gatsos, Monitrons and Truvelos were placed in the Temp file which was not speed zoned, whereas temporary SPECS were always in the SPECS file and speed zoned - but with no way to differentiate between temporary and permanent installations. As of todays release, all temporary cameras are prefixed with a "t" (tSPECS, tGATSO etc) and contained in the same files as the permanent installations. This also means that the Temp file is now disused so there is 1 less file to download / set up (although the file may still be downloaded for certain release formats until the next release!) |
and it's mentioned in this thread.
Having said all that, I've just discovered that I too still have TEMP:40090 showing _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Wed Oct 22, 2008 1:33 am Post subject: |
all the relevent software changes have been made now so next release (later today) will include a note to remove any temp file from your device as these will not be downloaded via ANY package
MaFt |
fordfocusmad Occasional Visitor
Posted: Thu Oct 23, 2008 6:37 pm Post subject: |
so are you saying the temp cameras are now discontinued on future releases?
Cant you remind me what the difference is betweens temp and specs cameras? |
Posted: Thu Oct 23, 2008 7:17 pm Post subject: |
thanks for the info I now understand , I updated the cameras last night and as you said the temp file will never be over written so I deleted and hey presto the offending camera has gone. |
Andy_P Pocket GPS Moderator
Posted: Thu Oct 23, 2008 8:40 pm Post subject: |
fordfocusmad wrote: | so are you saying the temp cameras are now discontinued on future releases?
The temp cameras are now included in the main gatso files (with a "T" at the front of the names.
There are two reasons for the change:
1. As there was only one "temp" category, there was no way on most satnav brands to know what the speed limit was for them.
Putting them into the speed-zoned main categories means you now get the correct speed alert.
2. The only cameras that tended to be categorised as "Temp" were the Gatsos on wheels. SPECS cameras in roadworks (although temporary) were already being put into the relevant speed-zoned SPECS files.
So the idea of the "Temp" category had really become an anachronism.
Now ALL temporary cameras are categorised by speed, you can delete the old temp file if you still have it. |
Posted: Thu Oct 23, 2008 8:42 pm Post subject: |
MaFt wrote: | so next release (later today) will include a note to remove any temp file from your device |
Did that happen, mate? I can't see a mention of it in the announcement of the new release in the Dedicated Subscriber forum section. |
Posted: Fri Oct 24, 2008 7:48 am Post subject: |
But what about if you don't have the speed zoned download.
I always just download the file which is just for gatso, specs, etc
So what will the difference mean in that download now if you don't have them speed zoned anyway.? |
Posted: Fri Oct 24, 2008 7:54 am Post subject: |
Quote: | But what about if you don't have the speed zoned download.
I always just download the file which is just for gatso, specs, etc |
All that's happened is the Temp cameras are moved to their relevant category and the TEMP files as it stands doesn't exists any more. So all TEMP GATSOs are now in the GATSO file as tGATSO, all TEMP SPECS are in the SPECS file as tSPECS etc etc
As you are downloading the Consolidated database, like me, you won't get a new TEMP file and icon with each download.
If you have any TEMP files and icons just delete them.
Quote: | So what will the difference mean in that download now if you don't have them speed zoned anyway.? |
Can you explain what you mean here? |
Posted: Fri Oct 24, 2008 10:18 am Post subject: |
Andy_P wrote: | MaFt wrote: | so next release (later today) will include a note to remove any temp file from your device |
don't you read the front page ;) |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Fri Oct 24, 2008 12:48 pm Post subject: |
MaFt wrote: |
Or maybe, like me, you updated before the extra note appeared on the front page? _________________ Paul |
Posted: Fri Oct 24, 2008 1:42 pm Post subject: |
or maybe i just forgot and addd it after andy kindly reminded me...
MaFt |
Posted: Fri Oct 24, 2008 7:56 pm Post subject: |
MaFt wrote: | or maybe i just forgot |
No, we don't believe that !!
You were beaten to it by the eager downloaders who were sitting to download the new release the very second it became available _________________ Andy
richard345 Frequent Visitor
Joined: Mar 09, 2008 Posts: 463 Location: Rainhill, Lancashire Not Merseyside!
Posted: Fri Oct 24, 2008 9:18 pm Post subject: |
That's so true! I only saw the front page announcement on the morning of the day after I downloaded and installed the update.
Can't believe it was forgotten, it must have been left in the ether in my Broadband connection. _________________ Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course! |
