keefy2 Occasional Visitor
Posted: Sun Oct 05, 2008 10:24 am Post subject: 720 dumped maps & apps |
My Go 720's battery went flat again when switched off and it has now lost all it's data. I managed to connect it to TT Home and reload the Apps but it wont let me have any maps unless I pay for them. This cannot be right as the unit is only 10 months old. What can I do to get my maps back? |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Sun Oct 05, 2008 10:37 am Post subject: |
Have you tried a pin reset? _________________ David |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Sun Oct 05, 2008 10:42 am Post subject: Re: 720 dumped maps & apps |
keefy2 wrote: | What can I do to get my maps back? | Have you done a Windows Explorer Backup? _________________ Richard
Posted: Sun Oct 05, 2008 11:13 am Post subject: |
Yes done both of them. It will not even let me restore from my previous backup! I seem to be able to get everything working except the map. |
uffe73 Frequent Visitor
Posted: Sun Oct 05, 2008 1:16 pm Post subject: |
keefy2 wrote: | Yes done both of them. It will not even let me restore from my previous backup! I seem to be able to get everything working except the map. |
If you have really done a full windows explorer back-up there shouldn't be any problem to copy the map back to your device from your PC. Are you sure you haven't used TomTom Home for you backup? |
Darren Frequent Visitor
![](modules/Forums/images/avatars/gallery/dg-caricature-73x73.png)
Posted: Sun Oct 05, 2008 1:32 pm Post subject: Re: 720 dumped maps & apps |
keefy2 wrote: | My Go 720's battery went flat again when switched off and it has now lost all it's data. I managed to connect it to TT Home and reload the Apps but it wont let me have any maps unless I pay for them. This cannot be right as the unit is only 10 months old. What can I do to get my maps back? |
As the battery has no bearing on data (it;'s stored in flash memory or on the SD card and is power independent) I'm confused as to what has happened here.
What 'apps' are you referring to and how have you lost everything? _________________ Darren Griffin |
peterc10 Frequent Visitor
Joined: Aug 21, 2005 Posts: 1761 Location: Kent, England
Posted: Sun Oct 05, 2008 1:48 pm Post subject: Re: 720 dumped maps & apps |
keefy2 wrote: | . This cannot be right as the unit is only 10 months old. What can I do to get my maps back? |
It is within its guarantee period - why not contact TT "support" and insist they sort out. If you get no luck with them take it back to where you bought it and demand they sort it out (assuming that is you are in the UK) _________________ Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Sun Oct 05, 2008 3:03 pm Post subject: |
Hi keefy2
You are in a pickle. However, if you made a proper Windows Backup it should work. Did you follow the instructions as described in the Sticky Tomtom Faq’s/How to backup my device? I know that the answer to that doesn’t help you in your present difficulty but when you are finally up and running again a proper Windows Backup is the first priority.
Believe me, it works and is designed to get you out of the trouble that you now find yourself in.
Good Luck. _________________ Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G |
Posted: Sun Oct 05, 2008 3:11 pm Post subject: |
I think we need to find out exactly what has happened first, a flat battery does not cause loss of data. _________________ Darren Griffin |
Posted: Sun Oct 05, 2008 7:47 pm Post subject: |
Hi Darren
You are right of course.
However, just out of curiosity what would happen If one was to disconnect the battery. On reconnection what would one have lost?
Out of curiosity I have often been tempted to find out for myself, but being British I rather leave that assignment to you folk. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
Posted: Sun Oct 05, 2008 7:51 pm Post subject: |
Trevor1234 wrote: | However, just out of curiosity what would happen If one was to disconnect the battery. On reconnection what would one have lost? |
You'd lose nothing at all, data is stored in flash memory and does not require power to store or retain. Removing the power would have no effect at all. _________________ Darren Griffin |
Posted: Sun Oct 05, 2008 8:32 pm Post subject: |
Hi Darren
By data I take it that you mean everything would still be there in the device except the actual contents of the Map Folder. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
Posted: Sun Oct 05, 2008 8:47 pm Post subject: |
No, by 'data' I mean everything stored on the device, program, voices, POIs, maps et al. All is stored in flash memory internally (or on a memory card in some devices) and all is impervious to power loss except where that power loss occurs as a particular file was being written to or read from. In that case the file in question might become corrupted but no more. _________________ Darren Griffin |
Tom59 Lifetime Member
![](modules/Forums/images/avatars/11432918549c7476f8ef95.jpg)
Joined: Aug 05, 2006 Posts: 407 Location: Alconbury - UK
Posted: Sun Oct 05, 2008 10:20 pm Post subject: |
I have an old original TomTom Go, which has been lying about in a drawer for the last eight months. I got it out last week, only to find that the battery was completely flat.
I put it on charge overnight and switched it on in the morning. There was no change of anything, even the last position that I drove to was showing on the display. _________________ TT Go 720 (T)
Firmware 9.430. Map: Western Europe V 875.3613
TT iPhone app
V 1.23 Map: Western and Central Europe 2 GB V 965.7286
TT iOS Go Mobile
V 1.1 Map: Western Europe 965.7248 |
Andy_P Pocket GPS Moderator
Posted: Mon Oct 06, 2008 1:30 am Post subject: |
Got a strange feeling of "deja vu" when I read this....
Felt sure I'd already done an answer once today.
Are you "OldWomble" HERE by any chance?
If it's not you, I'll say the same thing, can you do a screen grab or preferably a file listing of the contents of your TomTom storage memory, please?
(you can use a utility called DriveZ) |
