Pocket GPS World :: View topic - Speed on Tom Tom - accutate ??
PHILIP2908
PostPosted: Wed Sep 24, 2008 2:54 am    Post subject: Speed on Tom Tom - accutate ?? Reply with quote
I've had a Tom tom ONE for a couple of years now and have always noticed the the speed shown is about 5mph less than the speedo on my Passat.
Having recently driven 2000mls in the USA in a Dodge Charger - (truly awful car), but this had an integrated GPS system that provided internet radio on the move (fabulous) and I think must have driven the speedo, as for the first time the speed shown there, matched that on my Tom Tom which I took with me.
The question is: does anyone trust the speed shown on their SatNav when driving past speed cameras, SPECS etc rather than the dashboard instrument and not got a ticket??
I'm not brave enough yet - unless you tell me otherwise !!
Philip 2908
biggles150
PostPosted: Wed Sep 24, 2008 3:24 am    Post subject: Reply with quote
Hi PHILIP2908,
I'm going to start off with a bit of a moan. you joined this forum in 2005, and I can't believe you haven't come across one of the dozens of topics on this subject, moan over Wink
Suffice it to say that the GPS speed indication is more accurate than your speedo, which is designed to read approximately 10% over your actual speed.
I hope this is not going to be the start of an already well over discussed topic.
USE THE SEARCH FUNCTION.
Go Classic
Application 7.163 (8493/71205)
OS:2328
GB Map v710.1571
Sandisk ultra II 512MB
Calomax
PostPosted: Wed Sep 24, 2008 8:37 am    Post subject: Reply with quote
And if you find the other threads you will find that there is no corresponding law in the US that speedos have to overread so their's are usually accurate as you found on your trip.
TT Go Essential
PostPosted: Wed Sep 24, 2008 8:44 am    Post subject: Reply with quote
This is incorrect. US Federal standards also allow a maximum speedometer error of 5%.
Whilst you can find some cars anywhere that will read accurate, most won't as manufacturers inevitable err on the side of caution.
PostPosted: Wed Sep 24, 2008 8:46 am    Post subject: Re: Speed on Tom Tom - accutate ?? Reply with quote
In the US they have two satellite radio services, Sirius and XM. They have been very successful in the US because it is much easier to provide radio via satellite than maintain a network of terrestrial broadcast antennas. They share nothing with GPS except that they use satellite, different satellites, different orbits etc.
The speedo in the Dodge was just unusually inaccurate.
Calomax
PostPosted: Wed Sep 24, 2008 8:47 am    Post subject: Reply with quote
Sorry Darren, I meant they don't have to overread as the do have to in Europe
TT Go Essential
PostPosted: Wed Sep 24, 2008 8:51 am    Post subject: Reply with quote
Ah ok but in Europe they don't have to either. Legislation states they must be in the range 0% to +10%.
As they must not read under, manufacturers err on the side of caution most often and so configure them to over-read. They don't have to, it's just easier for them to do so.
peterc10
PostPosted: Wed Sep 24, 2008 11:34 am    Post subject: Reply with quote
Not a case of ease but necessity.
Speedos work by counting revolutions of the drive shaft and converting that to distance. But distance is a function of outer diameter of the wheel on the road and that can change a lot by factors such as make of tyre, tread depth and tyre pressure (not to mention things like using different size wheels and tyres on same model range but using standard speedo!)
So the range is needed to cope with all this and still make sure it does not under-read.
Peter
HTC Sensation
Copilot for USA
henryg
PostPosted: Wed Sep 24, 2008 11:43 am    Post subject: Reply with quote
Personal experience with my current and previous cars, seems to suggest that both speedos overestimated the speed by 3-4mph rather than a speed dependent percentage.
Henry
PostPosted: Thu Sep 25, 2008 4:19 pm    Post subject: Reply with quote
Please?
It's all been said so many times already, as Biggles says try the search function.
daimlerv8
PostPosted: Sat Sep 27, 2008 7:18 am    Post subject: Reply with quote
On a friends calibrated speedo........it read 4MPH faster than the Tom Tom
both the go 500 and the go 910 for an exact speed reading i trust the Tom Tom v my speedo. Wink
22.055 (29 May 24)
