Pocket GPS World :: View topic - Traffic set up problems. pls help!
Taz
PostPosted: Sun May 30, 2004 12:12 am    Post subject: Traffic set up problems. pls help! Reply with quote
Hi all,
OK, I'm at breaking point now :x I just cant get my Ipaq 5550 to run traffic updates via GPRS.
I had a Nokia with no bluetooth, so I have got a Sony Ericson t610 that will browse the net via GPRS on its own via O2 PAYG but as soon as I tell the iPAQ to connect, I get the message on the phone "GPRS accsess point not valid" and the only way to get the phone back online is to re install the WAP settings.
I have setup the iPAQ and phone as described here but to no avail.
I realy could do with some help please.
TIA
DavidW
PostPosted: Sun May 30, 2004 12:22 am    Post subject: Reply with quote
There's a difference between WAP over GPRS (which is what the phone's WAP browser uses) and full GPRS Internet access. I'm not sure the latter, which is required for TomTom Traffic, is possible on O2 pre-pay.
It would help if you gave more details of your settings - but I fear the issue is that you don't have access to the Internet APN on O2.
Taz
PostPosted: Sun May 30, 2004 6:38 am    Post subject: Reply with quote
David,
I can test that quite easily, my partner is on O2 contract so I will try her sim card Wink
In the mean time, what settings are you after and I will post them for you to look over.
Mason.
MrT
PostPosted: Sun May 30, 2004 7:11 am    Post subject: Reply with quote
02 PAYG does not support full GPRS internet access. 02 contract does, but I am having problems with 02 contract and TT traffic with incomplete data.
Orange PAYG supports full GPRS internet access at £4/MB
T-Mobile PAYG supports full GPRS internet access at £20/MB
Until the 02 contract issue is resolved I am using the orange PAYG with my IPAQ5550.
Taz
PostPosted: Sun May 30, 2004 7:36 am    Post subject: Reply with quote
Confused OK, then the GPRS access point error I am getting is down to PAYG ?
MrT
PostPosted: Sun May 30, 2004 8:11 am    Post subject: Reply with quote
Yes you get a GPRS access point error when you use the wrong Access Point Node for your network.
The O2 contract APN for GPRS mobile Internet is "mobile.02.co.uk" and the PAYG APN for WAP GPRS is "payandgo.02.co.uk"
If you use the additional modem string command on your iPAQ +CDGCONT=1,"IP","APN", where APN is the APN for your network, this will overwrite the first CID on the Ericsson T610. On the Ericsson T610 you use a different dialling number rather than the additional modem string to select which of your data accounts you want to use. The dialling number on an Ericsson is *99***CID# where CID is the CID of the data account you wish to use. On the Ericsson *99# dials the default CID=1.
On a Nokia you need the +CDG... string to select anything other than the default account and it does not overwrite. Dialling *99***CID# does not work on a Nokia. Again *99# on the Nokia without the additional string dials Active Access Point 1.
Taz
PostPosted: Sun May 30, 2004 9:10 am    Post subject: Reply with quote
Thumbs Up Thanks guys works a treat on O2 mothly pay. Guess I'll go buy an Orange PAYG sim now Rolling Eyes Smile
Thumbs Up
MrT
PostPosted: Sun May 30, 2004 11:22 am    Post subject: Reply with quote
Shop around, the an Orange SIM pack ranges from £9.99 to £29.99 (CarphoneWarehouse Website) for a blank SIM with £1 of credit. You may be lucky and find you get a free month of data or 12MB whichever is the smaller. Just try all you local retailers.
Taz
PostPosted: Sun May 30, 2004 11:26 am    Post subject: Reply with quote
Will do thanks. Although teher are plenty on Fleabay from around £4 Wink
DavidW
PostPosted: Sun May 30, 2004 12:38 pm    Post subject: Reply with quote
There's a typo here. It's +CGDCONT
*99***CID# does work on a Nokia - it's just that on most if not all Nokias there's only one Context ID, which, according to the 3GPP/GSM specifications is quite legitimate so long as it has the number 1.
MrT
PostPosted: Sun May 30, 2004 12:45 pm    Post subject: Reply with quote
What I find odd is that the Nokia 6310i can have up to six GPRS APNs programmed in, but only one context ID.
DavidW
PostPosted: Sun May 30, 2004 12:58 pm    Post subject: Reply with quote
I know - it's the way Nokia designed it. There's no real reason for it to be this way, as the 3GPP/GSM specifications, to my reading, say that it's permissible to allow multiple context IDs to be set up, but only one GPRS context to be active at once.
