marksam Occasional Visitor
Posted: Mon Apr 07, 2008 8:01 pm Post subject: Track up / north Up |
Hi I wonder if anyone can help, Since the new software I have not been able to use the Track up / north Up button as when I press it it does nothing, Im using the Southern UK map
can anyone help.
mark |
lucevans Frequent Visitor
![](modules/Forums/images/avatars/3593247754774ca51599f4.gif)
Joined: Mar 21, 2007 Posts: 261 Location: Cambridgeshire, UK
Posted: Mon Apr 07, 2008 8:27 pm Post subject: Re: Track up / north Up |
marksam wrote: | Hi I wonder if anyone can help, Since the new software I have not been able to use the Track up / north Up button as when I press it it does nothing, Im using the Southern UK map
can anyone help.
mark |
The new advanced power management is enabled by default in v1.16 of the software. When ON, this disables Track Up, forcing you to use North Up only.
If you want to use Track Up, go into the power management settings and select the normal power management option. |
Fellwalker1 Occasional Visitor
![](modules/Forums/images/avatars/gallery/scene_sunovermountains.jpg)
Posted: Fri Aug 29, 2008 1:30 pm Post subject: |
Cheers for the info
I was also trying to figure out why I could not alter the map orientation with the North up/Trail up button.
Keep up the great work ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) |
geoffers56 Lifetime Member
Posted: Wed Jan 14, 2009 9:22 am Post subject: Track Up / North up |
Lucevans
Thanks for the info on north up / track up.
Isn't it a pity the Satmap manual doesn't say this!!! |
LostMike Frequent Visitor
![](modules/Forums/images/avatars/18317326134dbc3e0165dbe.jpg)
Joined: Jan 17, 2008 Posts: 369 Location: Monmouthshire
Posted: Wed Jan 14, 2009 5:16 pm Post subject: |
geoffers56 said Quote: | Isn't it a pity the Satmap manual doesn't say this!!! |
But it does; on page 13 under Advanced Power Control. _________________ LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525 |
4ndynorfolk Regular Visitor
![](modules/Forums/images/avatars/gallery/1_satmap_active10.jpg)
Posted: Wed Jan 14, 2009 7:01 pm Post subject: |
Quote: | The new advanced power management is enabled by default in v1.16 of the software. When ON, this disables Track Up, forcing you to use North Up only. |
Are you saying that the upgrade should change all the sttings to default?
All my options, settings and routes (not on SD) remained. As did the last location and zoom level.
I just want to be sure that the upgrade installed properly.
I had an issue a few months ago with routes dissapearing. Satmap told me that this happened on occasions and the fix was to do a factory reset. My last location and some other settings survived this as well. |
jonesbach Regular Visitor
Posted: Wed Jan 14, 2009 7:36 pm Post subject: |
I can't comment on lukevans post but from memory I believe the 1.2 upgrade did reset everything to default while as you say the 1.3 upgrade seems to have left my settings unchanged. |
