Pocket GPS World :: View topic - Is there a fix for resuming Igo8 from standby?
floepie
PostPosted: Mon Jul 28, 2008 8:06 pm    Post subject: Is there a fix for resuming Igo8 from standby? Reply with quote
For whatever reason, I cannot resume iGo 8 from standby on my Axim, as I could with various other GPS navigation software in the past. Upon powering up the PPC, the app sort of hangs a bit and then closes itself. At least a soft reset isn't required, but it's a nuisance nonetheless.
linknet
PostPosted: Mon Jul 28, 2008 10:03 pm    Post subject: Re: Is there a fix for resuming Igo8 from standby? Reply with quote
I had a Dell Axim X51v and that's exactly what it used to do, I finally concluded, rightly or wrongly, that it was a lack of memory and sold the Dell. I replaced it with an iPAQ 214 with more free memory and it works perfectly.
linknet
floepie
PostPosted: Mon Jul 28, 2008 10:12 pm    Post subject: Reply with quote
Well, each of those devices has 64 MB SDRAM for running applications. I doubt that the Axim runs out of memory, which would result in the inability to resume from standby, but you never know.
Out of curiosity, why did you get rid of your Axim for the iPaq? They appear to have pretty similar specs. Anything I'm missing?
linknet
PostPosted: Mon Jul 28, 2008 10:25 pm    Post subject: Reply with quote
The Axim has 64 MB of RAM but the main problem is that it only has around 30-32 MB of free RAM. iGO8 would use virtually all of this leaving approx. 1 MB free. I used to get the same problem if I minimised iGO8 and then tried to run any other program, even running a tiny memory footprint program would then terminate iGO8.
The iPAQ 214 has 128 MB of RAM and around 90 MB of free RAM. iGO8 uses up to 70 MB of this leaving approx. 20 MB free.
The additional memory was the prime reason for the change.
linknet
mxmaciek
PostPosted: Thu Jul 31, 2008 10:56 pm    Post subject: Reply with quote
It seems that iGo8 is something like the vista Wink It works best when you have minimum of 512MB of RAM available exclusively for it Very Happy Very Happy Very Happy
Well, I'm starting to miss the apps running smoothly under win 2003... Smile
