Pocket GPS World :: View topic - hgv stuff for tomtom
Post new topic   Reply to topic    Pocket GPS World Forum Index -> HGV / Motorhome Lounge
pem1
PostPosted: Sat Feb 02, 2008 10:19 am    Post subject: hgv stuff for tomtom Reply with quote
get all your poi's for hgv's from this site and its free http://www.trucknav.napalmfiles.com/?dir=.&sort_by=name&sort_as=desc
stevieboy308
PostPosted: Mon Feb 11, 2008 12:14 am    Post subject: Reply with quote
hi all,
can anyone give me (an idiot!) an idiot guide on what program i need to open the files please.
cheers stevie
pem1
PostPosted: Mon Feb 11, 2008 8:36 pm    Post subject: Reply with quote
winrar m8 just google for it
BodgerBaz
PostPosted: Wed Feb 13, 2008 8:32 am    Post subject: Reply with quote
Newer versions of Winzip will also open them.
Stecha
PostPosted: Sat May 31, 2008 8:48 pm    Post subject: Reply with quote
Those are useful links, but, I have found today that the Industrial Estates file will not unzip properly. It unzips the image but not the locations. Confused Sad
BodgerBaz
PostPosted: Sun Jun 01, 2008 8:48 am    Post subject: Reply with quote
Either try again or send me a PM with your email address and I'll email it to you. The file contains both OV2 and CSV files - which one do you want?
Stecha
PostPosted: Mon Jun 02, 2008 11:18 am    Post subject: Reply with quote
BodgerBaz wrote:
Thanks Baz, pm on its way. Smile
BodgerBaz
PostPosted: Mon Jun 02, 2008 2:50 pm    Post subject: Reply with quote
Stecha wrote:
BodgerBaz wrote:
Thanks for that, PM with attachment on it's way.
Stecha
PostPosted: Mon Jun 02, 2008 10:26 pm    Post subject: Reply with quote
BodgerBaz wrote:
Stecha wrote:
BodgerBaz wrote:
Thank you again kind sir. I have received the attachment OK, but have had not had time to install. Wink
gixerste
PostPosted: Tue Jun 10, 2008 4:03 pm    Post subject: Re: hgv stuff for tomtom Reply with quote
Ok first off hi i'm a complete newbie to forum and HGV driving i have a tom tom one v3 will the stuff above work? mainly need low bridges/widths and weight limits cheers in advance Laughing
BodgerBaz
PostPosted: Sat Jun 14, 2008 8:23 am    Post subject: Reply with quote
Yes it will.
1. Download file
2. Unzip the file and choose your bridge height (for instance 10'6") the 'set' will be in 3 parts:-
‘Bridge 10’6.OV2‘ which is the bridge locations.
‘Bridge 10’6.BMP’ which is the little icon which will appear in your satnav.
‘Bridge 10’6.OGG‘ which is the warning sound.
3. Attach your satnav device to your PC or better still, insert your SD card into the PC. Whichever way you decide to do it you need to copy the three files above to the map folder on your SD card.
4. Now start your TomTom and touch the main map screen.
5. Select Change Preferences then Manage POIs (on screen 2 of 7).
6. Select Warn when near POI.
7. Navigate until you find the ‘Bridge 10’6’ POI (or whatever height you picked).
8. I have mine set for 5 miles (so I can take an alternative route in time) so have set the distance to 8800 yards.
9. Click YES when it says “Is this the sound you want?”.
10. Tick the box to accept the Warn only if POI is on route.
Go look for a bridge and try it - carefully :-)
tom9851
PostPosted: Sun Jul 06, 2008 2:00 pm    Post subject: Reply with quote
Does this freebie poi for low bridges have the same data as the poi being offered by lowbridges.com - they charge 9.95 - I don't mind paying for it as long as it's kosher - I currently just use the AA Trucker's Atlas which I think has about 1600 bridges listed but as you know they are mostly on major roads - the lowbridges.com site says they're poi has over 3000 bridges listed - I still use TomTom V3 (bit of a dinosaur I know!) and assume both these poi's will work ok with it?
Grateful for any info on this
Tom
___________
IPAQ2210/ROM-1.10/LEXAR 32X 256MB SD/Kingston ElitePro 1GB CF
TTN3-V3.03/Wired GPS-V3.03/Globalsat BT-338
BodgerBaz
PostPosted: Sun Jul 06, 2008 3:20 pm    Post subject: Reply with quote
The freebie set has 3,069 bridges listed with the highest one being 17'-9". Some are listed as '???' so you won't know what the height is until you see the road sign?
Stecha
PostPosted: Thu Jul 17, 2008 10:10 pm    Post subject: Re: hgv stuff for tomtom Reply with quote
Is this site run by anyone on here ?
I have two or three corrections from my locality to pass on if interested. Wink
mpwilson99
PostPosted: Sun Jul 20, 2008 9:01 pm    Post subject: Reply with quote
I would be interested to know what ones you have amendments for...
If you want, post me the locations of the bridges and i will see what i have for them!
MPW
Post new topic   Reply to topic    Pocket GPS World Forum Index -> HGV / Motorhome Lounge All times are GMT + 1 Hour
22.055 (29 May 24)
