BAVC10 Lifetime Member
Posted: Mon Jul 14, 2008 9:40 pm Post subject: Firmware 3.10 for Nuvi 7xx Series |
Garmin have released an update to version 3.10. Worked ok for me but haven't tested whether the home phone bug has been fixed yet
http://www8.garmin.com/support/download_details.jsp?id=3811
Change History
Changes made from version 3.00 to 3.10:
Improve handling of the situation where overlapping map data is present on the device.
Fixed fleet management interface route calculation issue.
Changes made from version 2.90 to 3.00:
Corrected issues with GPI files causing unit crashes
Corrected the expiring MSN Direct stocks after 5 days instead of 3
Corrected clipping at the beginning of voice instructions
Corrected compatibility issue with some MSN Direct receivers
Corrected issue with web favorites category display other types of points in MSN v2
Corrected local events not removing some dates correctly in MSN v2
Corrected GPI route display issues
Corrected Text language disappearing when changing modes
Corrected issue with Asian language support
Corrected issue with not being able to access additional information about GPI point
Corrected shutdown during postal code lookup |
Posted: Tue Jul 15, 2008 9:02 am Post subject: |
Cheers. Still haven't corrected the Phone Home bug despite their assurance that
Quote: | This issue was resolved in a recent software patch. Please update your software using the WebUpdater. |
and that was after i updated 3.00....
Going to try adding an extra digit after the Home number in the Nuvi to see if that "fixes" what Garmin can't / won't...
Edit: It didn't work. If you edit the number and then try it dials the whole number including the extra digit. Reboot the unit and it ignores the last two digits. Its as if it can dial the whole number before a reboot and only get the first 10 digits of a phone number after a reboot. |
RRconway Occasional Visitor
Posted: Tue Jul 15, 2008 12:38 pm Post subject: |
sorry, completely off topic but a fellow VC10 fan!!!!
they dont design them like that any more!!!! |
Lester_Burnham Frequent Visitor
Posted: Wed Jul 16, 2008 12:11 pm Post subject: |
PaulB2005 wrote: | Cheers. Still haven't corrected the Phone Home bug despite their assurance that
and that was after i updated 3.00.... |
Is that just a specific bug on the Nuvis / 700 series, then?
It seems to work fine on my C550. |
Posted: Wed Jul 16, 2008 12:23 pm Post subject: |
Quote: | Is that just a specific bug on the Nuvis / 700 series, then? |
Looks like it. If i dial Home using the Voice Dial or select it from the Phone Book in my Phone then all works well. However if you program your Home number into the Nuvi under the Home Location you get a Phone Home button. It works fine until you switch the system off. Upon restarting the Phone Home button will only dial the first 10 digits of any number.
I have told Garmin and they claim it's fixed. |
Posted: Wed Jul 16, 2008 12:47 pm Post subject: |
PaulB2005 wrote: | Quote: | Is that just a specific bug on the Nuvis / 700 series, then? |
Looks like it. If i dial Home using the Voice Dial or select it from the Phone Book in my Phone then all works well. However if you program your Home number into the Nuvi under the Home Location you get a Phone Home button. It works fine until you switch the system off. Upon restarting the Phone Home button will only dial the first 10 digits of any number. |
It was the latter scenario I meant - ie enter your home phone number, and use the direct button, rather than the phone book. I hadn't tried it after a restart of the gps, though.
Have now, and it still works, so must be model / series specific bug. |
Posted: Thu Jul 17, 2008 6:44 am Post subject: |
Anyone experiencing the unit switching off at random with the new update?
Yesterday 7 mile journey to client and it switched off near their house. Did the same on the way back too but it was in the same area so i assumed it was something about that location.
Travelling down a road i go down almost every day it switched off again. I didn't use it for the return leg though.
Going out later so will test again. Running demos now.
Unit was well charged and it was just a case of one minute it's on the next i look down and black screen.
Freakishly just as i typed "black screen" above it switched off!!!!! No error, just switches off......
Dear Garmin.......
Posted: Thu Jul 17, 2008 6:53 am Post subject: |
If i run the unit on the Garmin Mains Charger i bought then instead of switching off after 2 minutes the unit just freezes. |
Posted: Thu Jul 17, 2008 7:16 am Post subject: |
Downgraded to 3.00. Reset User data. Switched on, got a lock so i was at my Home Location. Switched on the GPS Simulator. Ran a simulated route to Garmin Europe as it's a built in Favourite when you reset user data. Simulated route. Ran for 4 minutes OK.
Upgraded to 3.10. Reset User data. Switched on, got a lock so i was at my Home Location. Switched on the GPS Simulator. Ran a simulated route to Garmin Europe as it's a built in Favourite when you reset user data. Simulated route. Ran for 1 minute and switched off.....
Back to 3.00 :-( |
eddieo Regular Visitor
Posted: Thu Jul 17, 2008 2:35 pm Post subject: |
wish I had read this before upgrading a couple of minutes ago....
driving to Italy tonight so don't really want any problems. just leaving it run through route now......
Paul, how do you revert back to 3.00 from 3.10 please |
Posted: Thu Jul 17, 2008 2:52 pm Post subject: |
Which Nuvi? It helps to have this information in your signature. You can add it by going into the Profile at the top of the forum.
You should never install an update unless you know you are going to be able to revert or have some time testing it. I only installed it as i knew i had a couple of days driving familiar routes.
1) Backup the Current.GPX file from Garmin\GPX folder and the POI.GPI file from Garmin\POI folder.
2) Download the relevant firmware from here
The files are named with the Nuvi model number and firmware version. You need nuvixxx_300.exe replace xxx with the relevant number from your model number (i.e. 710, 760, 770...) Download an save it to your PC.
3) With the Nuvi plugged into the PC run the downloaded program and follow the instructions.
4) When done unplug the Nuvi and leave alone for a few minutes. It'll take a while and will restart 2 or 3 times. The only thing you need to do is confirm you do want to install an older firmware and reset all user data. If you have backed up the files above you don't need to worry.
5) Once the unit restarts copy back the Current.GPX file and POI.GPI to the relevant folders and set the unit up again.
Every time there is a Firmware update you can download it separately from here and keep your own collection of Firmwares. |
Posted: Thu Jul 17, 2008 2:57 pm Post subject: |
I have the 770
it has been running through a route for approx 10 minutes so maybe OK? |
Posted: Thu Jul 17, 2008 3:00 pm Post subject: |
OK you need this one then.
Have a good time in Italy. I might want a chat when you get back about driving to Italy...... |
Posted: Thu Jul 17, 2008 3:05 pm Post subject: |
Quote: | it has been running through a route for approx 10 minutes so maybe OK? |
Possible. Yesterday i got 15 minutes down the road before it switched off - only 2 minutes from the destination Then on the way back around the same point it switched off again about the same point.
On a demo route this morning it only got 2 minutes into any demo before switching off. It was almost as if it was a certain point on the map or command caused it to switch off.
So i set my location at my In-Laws (325 miles away ) and tried a route back to here and it switched off 1-2 minutes into each trip. If i plugged the unit into the mains it froze instead of switching off.....
Revert back to 3.00 and it ran for 20 mins on both routes with no switch off. |
Posted: Thu Jul 17, 2008 3:31 pm Post subject: |
PaulB2005 wrote: | OK you need this one then.
Thanks! have reverted to 3.00 just in case
No prob's can advise regards routes... away for a month though |
