Pocket GPS World :: View topic - Postcode issue
Postcode issue
Bonzo-Dog
PostPosted: Fri Jul 04, 2008 6:57 pm    Post subject: Reply with quote
I have a question for you.
When using the postcode feature I key in the first 4 digits and it asks me for the address. That's not what I expect from a 'TomTom One XL.' My previous 'TomTom One' worked just fine....
Any ideas please? Embarassed
PostPosted: Fri Jul 04, 2008 7:02 pm    Post subject: Reply with quote
I have moved this to where it better positioned to receiver more applicable answers, as the original thread was about Garmins.
First of all when you select Navigate to/ Address/ Postcode you are infact making the selection as I have writted or are you trying to do something else? - Mike
Bonzo-Dog
PostPosted: Fri Jul 04, 2008 7:47 pm    Post subject: Reply with quote
Thanks Mike.
No, I'm doing as you say, but I can only type in the first 4 digits ie: RG22.
After that I can only type in the address as usual.
It sort of makes the feature useless doesn't it?
PostPosted: Fri Jul 04, 2008 8:00 pm    Post subject: Reply with quote
I assume you are in either Holland or UK? - can you connect the device to the PC and shutdown TomTom Home if it fires up. Use Windows Explorer and have a look at the list of folders is there a folder named "zip" if so are there any files in it - Mike
Bonzo-Dog
PostPosted: Fri Jul 04, 2008 10:49 pm    Post subject: Reply with quote
No Mike, no zip files at all.
PostPosted: Fri Jul 04, 2008 11:46 pm    Post subject: Reply with quote
There's a link to download the postcode files (and instructions on how to install them) HERE
Bonzo-Dog
PostPosted: Sat Jul 05, 2008 9:36 am    Post subject: Reply with quote
Hi Andy, nice of you to help. I've downloaded the 2 files as suggested and installed them. I'm not sure if the instructions are correct though, or maybe I just don't understand them.
Where do you paste the 2 UK files?
I didn't have a file named zip to replace as the instructions say.
files: Great_Britain.postal
Great_BritainPostal.ver
PostPosted: Sat Jul 05, 2008 10:28 am    Post subject: Reply with quote
Just create the folder named "zip" (without the "") in the root of your storage card and put the files in to it, then you will find full postcode support is present - Mike
Bonzo-Dog
PostPosted: Sat Jul 05, 2008 11:10 am    Post subject: Reply with quote
Yes thanks Mike, all seems OK now. I did have a bit of trouble but once the files are in the correct place it all seems to work OK. Embarassed
Many thanks to you all................ Embarassed
PostPosted: Sat Jul 05, 2008 11:16 am    Post subject: Reply with quote
Now its all working as it should be havew you considered backing up the device to the PC using Windows Explorer? - it is something I would recommend you do sooner rather than later. If you are unsure how to back up using Windows Explorer have a read through the links on the FAQ page which can be found Here - Mike
Bonzo-Dog
PostPosted: Sat Jul 05, 2008 2:40 pm    Post subject: Reply with quote
Thanks Mike but I'm well aware of the importance of doing your own personal backups. I am about to update my real soon.
I also use the TomTom facility just in case. You can never be too safe eh?
Cheers..........
PostPosted: Sat Jul 05, 2008 4:44 pm    Post subject: Reply with quote
No need...
Sorry to say I hadn't updated the instructions for the latest download location - it used to produce the rather confusing archive file "zip.zip", but now the archive is called "wezipcodes715.zip"
But the instructions are still right when they say:
....right click on it and select "Extract all".
It should extract to produce a folder called "zip" with four files inside.
Using Windows Explorer, you can copy and paste that folder onto the TomTom drive, replacing any existing folder called zip that may already be there.
Bonzo-dog, I've edited the instructions to give the new filename; is there anything else you think I should add to make it clearer?
Bonzo-Dog
PostPosted: Sat Jul 05, 2008 6:02 pm    Post subject: Reply with quote
Maybe just point out that the zip 'folder' goes in the root directory or drive.
No need to open the folder.
I had trouble with the rar (unzip) program that wouldn't let me select the folder to paste it, but one of the menu commands allowed me to copy it. (If that makes any sense?) Rolling Eyes
Oh yes, and it all works in firefox too.........
PostPosted: Sat Jul 05, 2008 7:44 pm    Post subject: Reply with quote
Thanks for that Bonzo, I'll amend the notes. Thumbs Up
By the way, if you are using Windows XP or Vista, you don't need any extra programs to "un-zip" the archive. You can just right click on it and select extract all.
Bonzo-Dog
PostPosted: Sat Jul 05, 2008 9:52 pm    Post subject: Reply with quote
Thanks, I'll remember that little tip.
22.062 (12 Jun 24)
