Pocket GPS World :: View topic - Garmin Nuvi 205T
Garmin Nuvi 205T
rbhuk
PostPosted: Thu Jul 03, 2008 9:55 pm    Post subject: Garmin Nuvi 205T Reply with quote
I've just bought a Garmin nuvi 205T, is there any way I can download a text to speech programme. !!
PaulB2005
PostPosted: Thu Jul 03, 2008 10:03 pm    Post subject: Reply with quote
If it didn't come with it, then i'm afraid no.
TTS is provided by the voice files which are provided by Garmin. Non TTS models can't use the TTS Voice files.
tsdinos
PostPosted: Thu Jul 03, 2008 11:59 pm    Post subject: Reply with quote
They can! But its illegal Very Happy
PaulB2005
PostPosted: Fri Jul 04, 2008 8:25 am    Post subject: Reply with quote
I didn't think the non-TTS unit had the capability in the firmware to "read" or "use" the TTS voices.
rbhuk
PostPosted: Fri Jul 04, 2008 9:00 pm    Post subject: Reply with quote
Sorry if I'm being thick, but how would I go about installing TTS on my nuvi 205T !!!!!!!!!!!!!
PaulB2005
PostPosted: Sat Jul 05, 2008 7:29 am    Post subject: Reply with quote
If, as tsdinos says, it's illegal, then you won't find that information here.
tsdinos
PostPosted: Sun Jul 06, 2008 1:33 pm    Post subject: Reply with quote
You can try and google it. There are some websites that have instructions, you will have to manually install them to the internal memory and maybe modify some files. Garmin's policy is not to include TTS voices to these units for commercial reasons obviously, but the hardware is perfectly capable to support them.
You may want to try over the internet to find instructions, but it will be your responsibility to modify the files.
If you decide to do so, remember to always back up the original files!
rutteger
PostPosted: Sun Jul 06, 2008 5:11 pm    Post subject: Reply with quote
If you are referring to the well known streetpilot tts hack I can confirm it doesn't work on the 255w and therefoire I assume the 205.
tsdinos
PostPosted: Wed Jul 09, 2008 12:07 pm    Post subject: Reply with quote
Basically.... I want to try something similar. My friend just bought a nuvi 250 that doesn't support TTS and i've checked its folders and in the folder voices it has british_english.sum and british_english.vpm
My nuvi 760T that supports TTS has in the same folder exactly the same files + British_english_daniel.sum and British_english_Daniel.vpm
I was just wondering if i simply copy these TTS files from my nuvi 760T to my friend's 250 is there any possibility it can work?
I wanted to try it now, but he is leaving on a trip tomorrow and I read on some forums that the Unit may crash or behave unexpectedly, so I wouldnt take the risk since he needs it tomorow, but i may try it on a later time
philpugh
PostPosted: Wed Jul 09, 2008 2:47 pm    Post subject: Reply with quote
No - it won't work. The 205 is missing the s/w modules that implement the text to speech algorithms. What you are seeing on the 7xx are the non-TTS voices - don't forget; you don't have to use TTS on these units. The navigation system 'talks' directly to the TTS speech module to implement TTS.
Phil
PaulB2005
PostPosted: Wed Jul 09, 2008 3:34 pm    Post subject: Reply with quote
I think there is one or two models it's been hacked on (C5XX?) but i don't think it's likely to be possible on newer models not designed to run TTS.
22.055 (29 May 24)
