Pocket GPS World :: View topic - TomTom GPS Driver 2.7 install with TN3
nickruss
PostPosted: Thu May 20, 2004 5:28 pm    Post subject: TomTom GPS Driver 2.7 install with TN3 Reply with quote
Hello
I have 2210 and TTN3 with fortuna clipon. Problem is (as advised by this forum) the GPS driver blocks the COM port for other applications like MM Navigator.
Advice is to install version 2.7 driver BUT HOW DO I DO THIS?
I tried downloading the driver ver 2.7 but ended up with tomtom3 not working either!
Thanks for any help
Nick
PostPosted: Thu May 20, 2004 6:37 pm    Post subject: Reply with quote
You need to uninstall your current GPS driver first. Then install v2.07.
nickruss
PostPosted: Thu May 20, 2004 6:49 pm    Post subject: Reply with quote
Thanks Darren, but what is the procedure for removing the current GPS driver? If I go to settings > remove programs, the only options are TomTom Navigatore, TomTom wizard and TomTom Voice.
I tried wizard but all my tomtom icons disappeared!
PostPosted: Thu May 20, 2004 6:57 pm    Post subject: Reply with quote
If there is a GPS Driver installed you should see TomTom~GPS, as you don't it suggests you have already uninstalled it?
What happens when you try to install v2.07?
nickruss
PostPosted: Thu May 20, 2004 7:05 pm    Post subject: Reply with quote
I dont see that, BUT
- tomtom works ok so it must have the driver
- when I install the 207 driver it asks me if want to overwrite existing driver files
So I've done that. If I start tomtom I get a series of beeps. No GPS menu so I go to the GPS icon and CANNOT enable the BT GPS tick box - just a beep.
What is the answer? Why does Memory Map have to use the TTN driver for GPS. Cant it use its own?
PostPosted: Thu May 20, 2004 7:11 pm    Post subject: Reply with quote
Have you tried a soft reset? Memory-Map does not require TomToms driver to work, it uses it's own BUT v2.08 and later of TomTom's GPS Driver blocked the BT Com Port and so 3rd party applications were unable to access a BT GPS.
If a soft reset does not work, install the latest GPS Driver (v3.02), this should correct the issue with it not appearing in Remove Programs. Once you have it showing in Remove Programs reply in this thread and I'll take you through the steps to unblock the port whilst still retaining v3.03.
nickruss
PostPosted: Thu May 20, 2004 7:22 pm    Post subject: Reply with quote
OK - I have done all that.
