Darren Frequent Visitor
Posted: Sun Jun 08, 2008 7:04 pm Post subject: Deal of the day: Navman B10 SSIII BT GPS |
Today's Deal Of The Day comes from Expansys, a Navman B10 Bluetooth GPS and more importantly a SiRFStarIII one at that.
The B10 is a fully fledged BT GPS with BT class 2 interface, integral rechargeable battery and small 63mm (H) x 41mm (W) x 17mm (D) size.
Expansys currently have these on offer at £19.95! Now that has to be a bargain! Navman's B10 spec page can be found here. _________________ Darren Griffin |
Tom59 Lifetime Member
![](modules/Forums/images/avatars/11432918549c7476f8ef95.jpg)
Joined: Aug 05, 2006 Posts: 407 Location: Alconbury - UK
Posted: Tue Jun 10, 2008 7:34 am Post subject: |
Does anyone know if this will work on a pda with standard Googlemaps or Microsoft livesearch? _________________ TT Go 720 (T)
Firmware 9.430. Map: Western Europe V 875.3613
TT iPhone app
V 1.23 Map: Western and Central Europe 2 GB V 965.7286
TT iOS Go Mobile
V 1.1 Map: Western Europe 965.7248 |
Posted: Tue Jun 10, 2008 7:36 am Post subject: |
It outputs the standard NMEA output so it will be fine with a PDA running GPS based software such as Google Maps- Mike |
Posted: Tue Jun 10, 2008 6:37 pm Post subject: |
Thanks Mike, I may well have to give it a go! _________________ TT Go 720 (T)
TT iPhone app
TT iOS Go Mobile
JockTamsonsBairn Lifetime Member
![](modules/Forums/images/avatars/202069601647f4a51ae4e4d.jpg)
Posted: Tue Jun 10, 2008 7:40 pm Post subject: |
Mike, (or anyone!), have you any experience of this particular model? My brother is thinking of getting one and I can't tell from the manual whether it has a "hard" power switch or not. The manual says Quote: | To turn on: Slide the button towards ON.
To turn off: Slide the button away from ON | In my opinion buttons don't slide, they depress!
He would want to be able to leave it connected to the car's power and have it switch on and off with the ignition, rather than having to dig it out of the glove box to press the button to switch it on. _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Tue Jun 10, 2008 7:45 pm Post subject: |
It has a switch, not a button, and will remain on as long as the switch is in the "On" position. Provided it's connected to a power supply, it will also remain charged. I've never run it down completely but would imagine that even from flat it will switch on again when a supply is present. _________________ Tim |
Posted: Tue Jun 10, 2008 8:15 pm Post subject: |
Thanks, Tim. That's what I was hoping to hear Have you tried using it without the battery? _________________ Jock
Posted: Tue Jun 10, 2008 8:22 pm Post subject: |
No, but give me a few minutes to dig it out...... _________________ Tim |
Posted: Tue Jun 10, 2008 8:32 pm Post subject: |
Ta! I'll owe you a pint! _________________ Jock
Posted: Tue Jun 10, 2008 8:44 pm Post subject: |
And the answer is, "Yes". With the battery removed and the unit plugged into a mains charger, my Nokia N95 still finds it. It also uses a slightly larger version (thicker) of the battery in my Nokia 6230i, so betteries should be in reasonably plentiful supply. _________________ Tim |
Posted: Tue Jun 10, 2008 8:49 pm Post subject: |
Thanks Tim! ![Guinness](modules/Forums/images/smiles/545.gif) _________________ Jock
