Pocket GPS World :: View topic - camera database
camera database
joe0543
PostPosted: Fri May 30, 2008 3:04 pm    Post subject: camera database Reply with quote
Having downloaded and installed the camera database onto my Zumo 550 I gave it a test run to check it out < I found that the only warnings I am getting are speed restriction zones ( ie, 70mph zone ect.)There is no indication of speed cameras/types as shown when I activate the built in garmin database,
Suggestion please
regards
joe Question
PostPosted: Fri May 30, 2008 5:07 pm    Post subject: Reply with quote
Hi Joe, I'm not that familiar with Garmin but I do know they only trigger if you exceed the limit as you approach a camera?
joe0543
PostPosted: Fri May 30, 2008 11:26 pm    Post subject: Reply with quote
Hi Darren
Even when exceeding the speed limit when approaching a known fixed camera site, my zumo only said (70mph zone ahead) ect .I think I will switch off the pocket gps info and try the Garmin data base to see what difference there is
joe
PaulB2005
PostPosted: Sat May 31, 2008 8:59 am    Post subject: Reply with quote
How did you install the database to the Zumo?
Do the camera appear in your Custom POIs? They should be listed under Where To?, Extras, Custom POIs
Have you got Proximity Alerts on? Spanner, Proximity Points, Proximity Alerts
PostPosted: Sat May 31, 2008 9:55 am    Post subject: Reply with quote
Joe, something is not right here, if you can answer Paul's questions we can get the bottom of this for you!
PostPosted: Sun Jun 01, 2008 1:31 am    Post subject: Reply with quote
hi joe,
just checked your download history and you've been getting the gpx files.
you will be better off going for: Garmin POILoader / Consolidated by Type
then you will get icons per camera type as well as specific speed warnings
joe0543
PostPosted: Fri Jun 06, 2008 12:13 pm    Post subject: spedd cams Reply with quote
Sorry to be late in getting back to you, Thanks for the info, I will check and see what comes up,
ps I am new to the system and not up to speed with it yet,
regards
joe
PostPosted: Fri Jun 06, 2008 6:53 pm    Post subject: Reply with quote
not a problem! everyone starts somewhere! also, cos we're all nosey here please do let us know how you get on!
joe0543
PostPosted: Sat Jun 07, 2008 9:48 pm    Post subject: SPEED CAMS Reply with quote
hI
Followed your advice, removed the previous download ind installed the new info as advised ,had a run out today and things seem to be working okay, ( speed cams now showing )When I come to check for updates, do I follow the same procedure,?
regards
Joe
PostPosted: Sat Jun 07, 2008 10:54 pm    Post subject: Reply with quote
Yes
PostPosted: Mon Jun 09, 2008 10:05 am    Post subject: Reply with quote
Yes, BUT just get the poiloader version this time! there's no need to download the gpx file then install and remove and then get the poiloader ones Laughing Laughing
just the poiuloader csv files Razz
joe0543
PostPosted: Thu Jun 12, 2008 8:57 am    Post subject: downloads Reply with quote
Thanks very much chaps.
regards
joe
