badgerdid Occasional Visitor
Posted: Wed May 14, 2008 11:30 am Post subject: Igo 8 pois |
Anyone know if its possible to import tomtom poi files into igo8 pois.
I searched and it seems there was a programme but this looks for a .db file, for 2006 i think, point of interests for igo 8 are .poi
any help appreciated, how am i going to cope not finding a mcdonalds? |
AdeyDiver Occasional Visitor
Posted: Fri May 16, 2008 2:29 pm Post subject: |
Using iGo explorer beta you can convert TomTom ov2 files to KML files.
Simply copy the converted kml to the \iGO8\CONTENT\USERDATA\POI folder and restart IGo 8.
You can then manage the new POI group in the normal manner.
Download from http://inetcom.hu/mick/igo/iGOPOIExplorerBeta.zip |
linknet Frequent Visitor
Posted: Sun May 18, 2008 12:25 am Post subject: |
PoiEdit will also convert TomTom ov2 files to kml and many other formats, and it's free !
linknet |
Posted: Sun May 18, 2008 12:38 am Post subject: |
Thanks guys, its working a treat.
Pity i have had to move away from tomtom but if there not going to support PDA's anymore, i have no choice |
Dunkelmann Occasional Visitor
Posted: Sun May 18, 2008 2:12 pm Post subject: |
badgerdid wrote: |
Me too. I'd been advised to go for iGO 8 but although I can get it to install on my iPAQ 2200 I can't get it to run. It just gives me an exception on starting up. I'm still waiting on iGO support to come back.
It's a pity TomTom have taken that attitude - it was the PDA users that helped it grow. |
Posted: Sun May 18, 2008 2:58 pm Post subject: |
Yes i know,
i must say i really like igo8 looks great on my hx4700. took a bit to get used to the menus etc but it works really well. |
craigdabbs Occasional Visitor
Joined: 13/05/2003 18:41:29 Posts: 6 Location: United Kingdom
Posted: Mon May 26, 2008 7:35 pm Post subject: |
im copying the kml files into the folder but there are not showing up on my manage poi screen. Any ideas where im going wrong? |
davast Lifetime Member
Joined: 19/08/2003 20:59:33 Posts: 61 Location: Warrington UK
Posted: Wed May 28, 2008 4:19 pm Post subject: |
Linknet - does this mean that one can download the pocketgps speed camera ov2 files and then convert them to klm format in POIedit and put them onto the Igo 8 map? |
Posted: Wed May 28, 2008 4:43 pm Post subject: |
davast wrote: | Linknet - does this mean that one can download the pocketgps speed camera ov2 files and then convert them to klm format in POIedit and put them onto the Igo 8 map? |
Yes, but you can't use the icons that come with them, you have to choose from the built in icons.
There is a way to add custom icons and I posted a file to download but can't remember where I posted it
Regards
linknet |
Posted: Wed May 28, 2008 4:57 pm Post subject: |
I knew it was somewhere
Convert your POI files to kml using POI-Edit or similar.
Copy the kml files to 'iGO8\contents\userdata\poi' folder.
Download this folder:
http://rapidshare.com/files/114572133/ui_igo8.zip.html
Unzip the ui_igo8 folder and copy it to the iGO8 root folder on the SD card giving 'iGO8\ui_igo8'.
Start iGO8 and go to manage POI and you should see your new POI's and new icons at the end of the default icons.
If you don't like the new icons you can edit the poi_brand_rect.bmp files but make sure you retain the alpha data channel.
Regards
linknet
chrisnewman Occasional Visitor
Posted: Thu Jul 10, 2008 2:41 pm Post subject: Doesn't work |
I've downloaded the ui files put them on my SD card and got my ov2 files and converted them using POI editor and put them on the SD card although I have no userdata\POI folder so tried creating that and didn't work.
My file structure on SD card is \SD Card\iGo8\Content\POI and in this folder at the moment is UnitedKingdom.poi
So my question is how the heck do I amend this all in one POI file, it's 2.35 Mb and as I say the above method doesn't work at all? Can someone please help out a frustrated iGo user?
TIA
Fixed it, typo on a folder, doh |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Thu Jul 10, 2008 4:42 pm Post subject: |
you should be able to create the following:
Storage Card\iGO8\contents\userdata\poi\
then put the files here. restart igo8 and it will pick them up
MaFt |
Posted: Thu Jul 10, 2008 5:15 pm Post subject: Thanks |
That's where I messed up
Thanks |
ervius Occasional Visitor
Posted: Sun Aug 10, 2008 2:14 pm Post subject: |
if you want insert your own pois, (creating new user.upi file, or creating single kml files from asc, csv or ov2 files!!!), try this software, only have to choice icon, choice poi cathegory to insert, and repeat operations for all pois you need, and then you have:
or all kml you need or new extended user.upoi.
user.upi created, bust be inserted, overwritting esisting, into :\iGO8\save\ folder, while:
*.kml files, must be inserted into:
\iGO8\CONTENT\USERDATA\POI\ folder
then you will be able to see new poi cat. into poi of igo8 ;)
bye!!!
download program here:
Code: |
http://www.mediafire.com/download.php?yosxoypwjoo
christis Occasional Visitor
Posted: Fri Sep 19, 2008 10:47 am Post subject: |
ervius wrote: | if you want insert your own pois, (creating new user.upi file, or creating single kml files from asc, csv or ov2 files!!!), try this software, only have to choice icon, choice poi cathegory to insert, and repeat operations for all pois you need, and then you have:
bye!!!
Code: |
Sounds great my friend, but Mediafire gives me an Invalid file error. PLease check and reupload or whatever because I am in great need for this.
Thank you |
