jaycr Occasional Visitor
Posted: Fri May 09, 2008 10:16 pm Post subject: Brodit active mount for Go730? |
Hi, just wondered if anyone knows whether the Brodit active mount for a Go720 could also be used for a Go730? Apparently the units are exactly the same but does anyone know for sure?
Many thanks. |
Andy_P Pocket GPS Moderator
Posted: Mon May 12, 2008 12:07 pm Post subject: |
I think there's been a mention of this somewhere... maybe on the topic where the 720 mount was reviewed?
Everyone says the hardware of the x20 and x30 models is the same, but Brodit seemed to say the USB socket was very slightly differently placed. |
GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Mon May 12, 2008 3:51 pm Post subject: |
I thought there was mention of the 930 vs 920 mount in this thread, but I couldn't find it when I just flicked through.
However, there was a picture of the bottom of the 930 and the USB port seems to be in the same position as the 720 - so I'm not 100% _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
Posted: Mon May 12, 2008 4:36 pm Post subject: |
I am sure there is a difference of a few MM between the position of the mini USB socket from what Brodit have mentioned somewhere, there will also need to be an alterration to the cable assembly for the new RDS receiver that was announced a couple of weeks ago with the launch of the 'even newer edition' TomTom One products. This assumes that TomTom will switch to the newer RdS device for all models at some future point.
It is not possible for me to confirm the physical dimensions with my 930 and 720 as they are not necessarily the same as a true production built device - Mike |
Darren Frequent Visitor
Posted: Mon May 12, 2008 5:22 pm Post subject: |
There is a difference of one or two mm's in the position of the USB socket. certainly on a Carcomm cradle this causes problems as whilst the USB can 'mate' it prevents the RDS-TMC antenna connection from fully connecting unless forced. As this has already proved to be a weak point on the x20's I'd be very wary of doing so.
Carcomm will shortly be releasing x30 compatible cradles and I'll seek comment from Brodit on the availability of 'Active' x30 solutions. You will see from their website that they do not list any for x30's at present because of this issue.
Why the design has changed in this way I can only speculate. Either there has been a radical internal re-design necessitating the change or TomTom are just being bloody minded to force 3rd party accessory manufacturers to re-tool. I'll have a 930 very shortly and will open it up to see! _________________ Darren Griffin |
Posted: Mon May 12, 2008 6:20 pm Post subject: |
Thanks for your replies guys. I think I'll wait until there's a specific X30 type released. |
Erintech Occasional Visitor
Joined: 12/09/2003 15:19:48 Posts: 39 Location: United Kingdom
Posted: Tue May 13, 2008 11:16 pm Post subject: |
I bought a Brodit active mount for a 920T and am now using it with a 930T.
The fit appears to be identical.
The problems will arise when TomTom come out with the newfangled traffic adaptor thingy (do I mean HD traffic?) which I assume will need a new active mount. _________________ TomTom 930T |
Posted: Wed May 14, 2008 7:31 am Post subject: |
Erintech wrote: | I bought a Brodit active mount for a 920T and am now using it with a 930T.
The problems will arise when TomTom come out with the newfangled traffic adaptor thingy (do I mean HD traffic?) which I assume will need a new active mount. |
Are you using it with the Traffic Antenna? It may be that Brodit's design where the antenna is attached to the mount allows for more 'give'. _________________ Darren Griffin |
Posted: Wed May 14, 2008 10:31 am Post subject: |
No, not using the traffic antenna - I'll take a look at the fit this evening... _________________ TomTom 930T |
JaguarV12e Regular Visitor
Joined: Feb 07, 2005 Posts: 171 Location: Cambridge UK
Posted: Mon Jun 09, 2008 7:36 pm Post subject: |
I ordered a Brodit active mount (Item 273006) for my 730T from their web site and the packaging states that it fits 520T 530T 720T 730T 920T and 930T.
It seems to fit the connectors perfectly.
It is a bit more tricky to slide the TT into mount than I expected, because the swivel swivels with less force than it takes to depress the spring in the back of the 730. _________________ Tomtom Go 1005
Tomtom Go 730T |
Posted: Mon Jun 09, 2008 7:44 pm Post subject: |
JaguarV12e wrote: | It is a bit more tricky to slide the TT into mount than I expected, because the swivel swivels with less force than it takes to depress the spring in the back of the 730. |
You can increase the friction on the ball joint by tightening the centre screw. _________________ Darren Griffin |
Tomo Lifetime Member
Joined: May 17, 2004 Posts: 212 Location: Fife Scotland
Posted: Mon Jun 09, 2008 8:28 pm Post subject: |
Another confirmation here, bought a active mount for TT520T now using it with 730T.
Part numbers when you do a search on brodit.com are identical for traffic and non traffic versions for x20 and x30
Steve |
Kremmen Pocket GPS Verifier
Posted: Tue Jun 10, 2008 7:02 am Post subject: |
I think TT should produce a hardwire solution for their complete range in a similar fashion to the 730 desk dock.
It would be extremely neat and could sit on the top of the dash of the majority of vehicles. _________________ DashCam:
Viofo A119 V3 |
Posted: Tue Jun 10, 2008 7:30 am Post subject: |
Kremmen, have a read of This Thread which shows how to convert the desk dock from an x20 to a car holder, it is still in regular use today - Mike |
Posted: Tue Jun 10, 2008 7:33 am Post subject: |
TomTom are committed to solutions that do not encourage owners to leave their device and or mount on display and I think that's the right move.
For those of us that wish a permanent mount there is Carcomm and Brodit. _________________ Darren Griffin |
