Pocket GPS World :: View topic - Track up / north Up
Track up / north Up
marksam
PostPosted: Mon Apr 07, 2008 8:01 pm    Post subject: Track up / north Up Reply with quote
Hi I wonder if anyone can help, Since the new software I have not been able to use the Track up / north Up button as when I press it it does nothing, Im using the Southern UK map
can anyone help.
mark
lucevans
PostPosted: Mon Apr 07, 2008 8:27 pm    Post subject: Re: Track up / north Up Reply with quote
can anyone help.
mark
The new advanced power management is enabled by default in v1.16 of the software. When ON, this disables Track Up, forcing you to use North Up only.
If you want to use Track Up, go into the power management settings and select the normal power management option.
Fellwalker1
PostPosted: Fri Aug 29, 2008 1:30 pm    Post subject: Reply with quote
Cheers for the info Thumbs Up
I was also trying to figure out why I could not alter the map orientation with the North up/Trail up button.
Keep up the great work Very Happy
geoffers56
PostPosted: Wed Jan 14, 2009 9:22 am    Post subject: Track Up / North up Reply with quote
Lucevans
Thanks for the info on north up / track up.
Isn't it a pity the Satmap manual doesn't say this!!!
LostMike
PostPosted: Wed Jan 14, 2009 5:16 pm    Post subject: Reply with quote
But it does; on page 13 under Advanced Power Control.
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
4ndynorfolk
PostPosted: Wed Jan 14, 2009 7:01 pm    Post subject: Reply with quote
Are you saying that the upgrade should change all the sttings to default?
All my options, settings and routes (not on SD) remained. As did the last location and zoom level.
I just want to be sure that the upgrade installed properly.
I had an issue a few months ago with routes dissapearing. Satmap told me that this happened on occasions and the fix was to do a factory reset. My last location and some other settings survived this as well.
jonesbach
PostPosted: Wed Jan 14, 2009 7:36 pm    Post subject: Reply with quote
I can't comment on lukevans post but from memory I believe the 1.2 upgrade did reset everything to default while as you say the 1.3 upgrade seems to have left my settings unchanged.
