Pocket GPS World :: View topic - Continental Safety Cameras
FrankCatlow
PostPosted: Mon Feb 25, 2008 6:13 pm    Post subject: Continental Safety Cameras Reply with quote
Can someone tell me how I can get UK and European Safety Cameras on my Garmin Nuvi 360 at the same time.
I can only see how to download UK or European
PostPosted: Mon Feb 25, 2008 6:14 pm    Post subject: Reply with quote
First post since you joined Frank Very Happy Download both to the same folder on your PC and then upload using POILoader? As I understand the process, Garmin imports all POIs in one go so all those that you wish to upload have to reside in the same folder before you launch POILoader
PostPosted: Tue Feb 26, 2008 11:24 am    Post subject: Reply with quote
not getting t you darren but...
doing it that way will set up the non-uk (i.e. kph) files incorrectly. you need to load the non uk ones separately and set them to kph in poiloader. then, within the devices memory (via my computer' you need to rename that file. THEN run poi loader with all your uk pois (in mph) to get them both on.
more info from the sticky thread here: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=57496
PostPosted: Tue Feb 26, 2008 11:37 am    Post subject: Reply with quote
No problem and thanks for the clarification Smile
PostPosted: Tue Feb 26, 2008 11:39 am    Post subject: Reply with quote
the main problem is caused by poiloader automtically removing any pre-installed pois when new ones are added (hence the rename) and the fact that ALL files you upload MUST be done in the same format (mph/kph) hence having to do it twice...
still, it's a fairly simple workaround
