Pocket GPS World :: View topic - NMEA/SiRF mode?
NMEA/SiRF mode?
Goto page Previous  1, 2, 3, 4, 5
philpugh
PostPosted: Tue Jul 04, 2006 6:44 pm    Post subject: Reply with quote
Quantum wrote:
Come to think of it, isn't it possible to set TomTom for going on foot? Maybe this is what it actually does.
The "On foot" setting in TomTom just tells the routing algorithms to ignore the restrictions on one-way and pedestrianised areas - which obviously need to be adhered to in a car/motor-bike etc. The snap-to-centre-line is still in operation. If you want altitude use a topo-mapping program like OziexplorerCE (www.oziexplorer.com) excellent s/w - and I am only a user of it before anyone asks! It doesn't do routing however - but you can have fun creating your own routes with waypoints - just like real navigating Wink
amdaman
PostPosted: Sat Aug 26, 2006 5:06 pm    Post subject: Reply with quote
Is there any advantages of running SiRF mode over NEMA then? Both modes work with TomTom for me but I have to say NEMA with WAAS enabled is very accurate indeed.
PostPosted: Sat Aug 26, 2006 5:24 pm    Post subject: Reply with quote
I would leave the SiRF mode alone stick to NMEA, there are certain tweaks you can perform with SiRF but for car navigation NMEA is fine, I do use SiRF when using the GPS for walking to turn off the Static Navigation, I have also found very little difference in the positional accuracy with the WAAS set to on or off.
Just for the record TomTom version 5 will only work using the NMEA data protocol, so I would guess you are using TT vs3 or earlier? (I have included this last part incase someone switches their receiver to SiRF and wonders why TomTom has sudenly stopped working - Mike
oferb
PostPosted: Mon Feb 18, 2008 2:38 pm    Post subject: gplim 236 crash from sirf demo Reply with quote
[quote="Quantum"] Whatever you do, don't use SiRFDemo, as it seems it switches at the same time, mode to SiRF and baud to 57600. Unfortunately bluetooth can only run at 38400, so the 236 goes dead. Even Holux warned me against SiRFDemo, and implied the 236 cannot work in SiRF. I have tried to confirm this, but they are now not responding. ([url=mailto:Water_Lin@holux.com.tw]Water Lin[/url]) Some pods inhibit the baud change command, but I gather that the 236 does not, and just commits suicide.
well I just did that Sad
and now my 236 is transmitting garbage if it does anything at all.
is there a way back?
Thanx
well.. 2 hours later - found this place
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=44809
and it is back to normal
Thanx
AllyCat
PostPosted: Mon Feb 18, 2008 3:09 pm    Post subject: Reply with quote
If you're patient, then just take out the battery and wait for several days. When the internal backup battery goes flat then the GPS will revert to the NMEA factory default. If you're in a hurry and prepared to take a risk, then it's possible to prise open the case (don't lose the on/off switch) and short-circuit the button cell for a few seconds to achieve the same result.
Alternatively, the excellent SirfTech PPC program may be able to identify the current data format and allow you to reset the Holux.
Cheers, Alan.
Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Acer N50,HP114,Loox N560,Dell x50,CF/SD cards to 4/32GB.
RoyalTek,Holux236,Navman B10 & Copilot(Globalsat) BT GPS,TomTom5/6.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter.
Page 5 of 5
