Pocket GPS World :: View topic - problems installing the data base on memory map
pko
PostPosted: Fri Feb 01, 2008 4:07 pm    Post subject: problems installing the data base on memory map Reply with quote
Hello, I have downloaded the csv speed camera details for memory map but when I try to install them Memory Map rejects them & displays the message "bitmap file for icon must be 32x32 pixels-16-colours uncompressed". your icons I see are 22x22.
Can you advise as to what I must do to enter them into Memory Map?
many thanks
PostPosted: Fri Feb 01, 2008 4:55 pm    Post subject: Reply with quote
which files did you want to use? single file? consolidated? speed zoned?
i've created some 32x32 files for single file and consolidated here:
http://www.pocketgpsworld.com/memorymap_bmp.zip
They are saved as 8-bit but not sure about the '16 colours'?
if you let me know if they work or not!
pko
PostPosted: Fri Feb 01, 2008 5:39 pm    Post subject: to MaFt Reply with quote
many thanks for your prompt reply. I've tried adding the files you suggested but I am still getting the same message that they must be 32x32 etc. even though your ones are showing as 32x32. The odd thing is though that the files I deleted from Mem.Map before installing this update are 22x22 & they worked fine. I'd be grateful for any other suggestions.
kindest regards
rothers
PostPosted: Fri Feb 01, 2008 6:08 pm    Post subject: Reply with quote
Memory Map icons need to be 16 colour (4 bit) not 256 colour.
pko
PostPosted: Tue Feb 12, 2008 6:04 pm    Post subject: icons Reply with quote
Hi. MaFt I've been away from computer for a while, but on checking today there seems to be no solution to my problem with installing the database onto memory map. I have tried all 3 data bases but none work. I see rothers says they must be 4 bit, but that doesn't mean much to me. Any further suggestions would be appreciatted.
regards pko
Brian
PostPosted: Tue Feb 12, 2008 6:15 pm    Post subject: Reply with quote
Load Mafts icons into Microsoft Paint (Windows / Start / Accessories / Paint) then resave using .. (File / Save As ) .. and select 16 Colour Bitmap ( as opposed to 256 Colour or 24 Bit etc) as the file type. See if that works.
Aprilia Tuono, Zumo 550
Ipaq 2210/Fortuna/TomTom Nav6
& Road Angel 7000 + Memory Map
pko
PostPosted: Wed Feb 13, 2008 5:54 pm    Post subject: Reply with quote
brian, many thanks, problem solved.
PostPosted: Wed Feb 13, 2008 5:59 pm    Post subject: Reply with quote
thanks brian! but hey, at least i got the size right!!
Brian
PostPosted: Wed Feb 13, 2008 10:22 pm    Post subject: Reply with quote
It was just a combination of MaFts and Rothers info Laughing
22.055 (29 May 24)
