stuart Frequent Visitor
Joined: 20/04/2003 11:51:10 Posts: 405 Location: Dorset, England, Great Britain
Posted: Fri Feb 01, 2008 12:40 pm Post subject: Latest Home version |
Has anyone managed to make their own 'Map Overlays' yet. TomTom have an example with the CeBit Exhibition Centre. How about one of the NEC in Birmimgham.
Or something more exciting.
http://create.tomtom.com/manuals/create-your-own-content/ |
Posted: Sat Feb 02, 2008 9:54 pm Post subject: Re: Latest Home version |
I have a few created on my device but they are for restricted area sites so I don't think publishing them on the site would be a very a good idea! - I will try and set one up covering the local park tomorrow and see if that can be used to get some screen shots/ photographs.
This would appear to work in a very similar way to the method I used to employ to run map bmp files on the device for areas with no coverage using the excellent "Off Road Navigator" plug in for the TT devices, although the zoom control parts are new, and the way it adds the image to the existing map view.
To create one grab a screen shot of the area you want using Google Earth with a couple of position "pins" located at known coordinates top left and bottom right, then use a photo edit package on the PC to edit the picture down to the simple image you require - Mike |
Posted: Sat Feb 02, 2008 10:06 pm Post subject: Re: Latest Home version |
mikealder wrote: | I have a few created on my device but they are for restricted area sites so I don't think publishing them on the site would be a very a good idea! Mike |
I understand Mike, and looking at your home location, I can understand why (possibly). I get to go to a large site just south of you and a similar one on the east coast, plus one down near me. I may tweek one of the suppied site maps and see how it goes. I'll watch this forum for your results. Stu |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Sun Feb 03, 2008 9:53 am Post subject: Re: Latest Home version |
stuart wrote: | Has anyone managed to make their own 'Map Overlays' yet. TomTom have an example with the CeBit Exhibition Centre. How about one of the NEC in Birmimgham. |
I have had a go at creating one for the NEC here
It shows the halls and the car parks. It's my first attempt and the resolution is not as good as I would have liked.
It was created by grabbing a couple of screen shots from the tomtom, stitching them together, adding the car parks & halls with a paint program and erasing the roads leaving the background colours in place to blend in with the rest of the map (of course this will only work if your map colours are the same as mine).
Anyone know how to get a clear background? Tried a gif with a transparent background, didn't work! |
Posted: Sun Feb 03, 2008 12:57 pm Post subject: Re: Latest Home version |
pcaouolte wrote: |
pcaouolte
I have downloaded it and will check it out later today. Thanks for being the first . |
uffe73 Frequent Visitor
Posted: Sun Feb 03, 2008 7:13 pm Post subject: Re: Latest Home version |
stuart wrote: | pcaouolte wrote: |
pcaouolte
I create one too today and it worked, except that the roads on the map overlay diverted sligtly from the roads on the TomTom map when I zoome in. It is tricky to get the long/lat values of the corners of the overlay exact. Since the map picture I used is copyrighted I can't distribute it. |
GerryC Pocket GPS Moderator
Posted: Sun Feb 03, 2008 8:52 pm Post subject: Re: Latest Home version |
pcaouolte wrote: | I have had a go at creating one for the NEC here
Just checked and it looks really useful - fills the gaps in nicely. I suspect you would get better resolution and "fit" to the roads better by using a bigger image (more zoomed in) but over the same area. Your's is only a pixel or two out at worst anyway so I wouldn't bother too much.
Unfortunately, bmp files don't have transparency though you wouldn't want it (what if someone's normal background was the same colour you used for the car parks for example). _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Posted: Sun Feb 03, 2008 9:14 pm Post subject: |
pcaouolte I have added your map overlay onto my TTG500 and it looks fine..I'll give it a road test next time I make a delivery there.. Cheers...
uffe73...What is your overlay of... |
Posted: Sun Feb 03, 2008 9:49 pm Post subject: |
stuart wrote: | pcaouolte I have added your map overlay onto my TTG500 and it looks fine..I'll give it a road test next time I make a delivery there.. Cheers...
It's a detailed orienteering map (1: 10 000) for the area where I use to run. Just for testing the overlay feature (not very useful to bring the TT GO out in the jogging track ). |
Posted: Sat Feb 09, 2008 5:08 pm Post subject: Re: Latest Home version |
I know I am quoting myself, but with mikealders help, I have managed to make my own overlay for a location in Ghent, Belguim. I will be testing its accuracy this Monday coming.
thanks mike |
metradio Occasional Visitor
Joined: Sep 03, 2006 Posts: 24 Location: Slough, Berkshire
Posted: Sat Feb 09, 2008 9:37 pm Post subject: Re: Latest Home version |
pcaouolte wrote: | stuart wrote: | Has anyone managed to make their own 'Map Overlays' yet. TomTom have an example with the CeBit Exhibition Centre. How about one of the NEC in Birmimgham. |
I have had a go at creating one for the NEC http://homepages.nildram.co.uk/~coote/tt/raster/nec.zip
It shows the halls and the car parks. It's my first attempt and the resolution is not as good as I would have liked....
Not a bad effort all the same.. I ran the bmp image through PaintShop Pro and expanded it to 200% of its original size, sharpened the image up and saved it as a GIF file to save on file size. I also altered the nec.sat file to reflect the new image size and altered the zoom level figure from 30 to 90 so the overlay can viewed further out on my TomTom One V1.. |
Posted: Tue Feb 12, 2008 5:42 pm Post subject: Re: Latest Home version |
[quote="metradio
Not a bad effort all the same.. I ran the bmp image through PaintShop Pro and expanded it to 200% of its original size, sharpened the image up and saved it as a GIF file to save on file size. I also altered the nec.sat file to reflect the new image size and altered the zoom level figure from 30 to 90 so the overlay can viewed further out on my TomTom One V1..[/quote]
Hi metradio...Any chance of you emailing the GIF and sat file through to me please. I have done a local OS Map for my TTG 500 which works OK. Is that right that the overlay can only be viewed in the 'Browse map' option.
Posted: Tue Feb 12, 2008 7:26 pm Post subject: Re: Latest Home version |
stuart wrote: |
PM sent..
Quote: |
Is that right that the overlay can only be viewed in the 'Browse map' option. |
Yes it is :-(
Mike _________________ Mike Burgess
TomTom One IQ Routes
TomTom Traffic Receiver V3
Mobilnova Media Center |
Posted: Fri Feb 22, 2008 8:00 am Post subject: |
I split this topic from the original Home 2,2,0,33 thread as a few people are asking questions about this, finding the information was a little difficult as it was spread across six pages, I hope no one minds - Mike |
meinereiner Occasional Visitor
Posted: Sat Mar 08, 2008 6:52 pm Post subject: |
Hi, since I do not speak English translation with google.
I have this forum with Google and found this story with interest since I read in German no discussion on map overlays found.
Have also created overlays recognizes TomTom Home unfortunately it is not and I can not for all this Release.
Name of overlays:
1.sat
This content:
8.xxxxx
50.xxxxx
8.xxxxx
50.xxxxx
0
65535
315
315
The same again with a jpg tried both in the map.
Can someone tell me why TomTom Home does not recognize the overlays?
Orginal
Hi, da ich keine Englisch spreche hier die Übersetzung mit google
Ich habe dieses Forum mit Google gefunden und mit Interesse diesen Beitrag gelesen da ich in deutsch keine Diskussion über Map overlays gefunden habe.
Habe auch Overlays erstellt leider erkennt TomTomHome diese nicht und so kann ich diese nicht für alle Freigeben.
Name der Overlays:
1.sat
mit diesem Inhalt:
8.xxxxx
50.xxxxx
8.xxxxx
50.xxxxx
0
65535
315
315
das selbe nochmal mit einem jpg versucht beide werden in der Karte angezeigt.
Weis jemand warum TomTom Home die Overlays nicht erkennt? |
