Pocket GPS World :: View topic - Walking a pre planned walk
FrequentFlyer
PostPosted: Sun Feb 03, 2008 4:22 pm    Post subject: Walking a pre planned walk Reply with quote
Do I assume that you can join a pre planned walk anywhere along the route,as to apposed to my original start point, and just 'go'? What would I do.....check that I am on the walk (GPS Position,) and then just 'activate'? I assume that there is no, sort of, message...'you are nearly on your designated path!'
robs1972
PostPosted: Sun Feb 03, 2008 5:56 pm    Post subject: Reply with quote
The route is just a yellow line on the map and you follow it if you want to.....it appears on the map whether it is activated or not (it's grey when not activated).
You can make it a bit more sophisticated if using the databox overlays because you can make it show, among other things, distance or time to next waypoint or route end etc...but if you decide to do a detour it just shows the distance you are from the waypoint increasing and of course you can see your current location in relation to the line on the map.
I like mapping, I like mapping, I like mapping and I like to map!
22.062 (12 Jun 24)
