Pocket GPS World :: View topic - TOMTOM GPS 3.02 Upgrade available
dksbbs
PostPosted: Fri Apr 23, 2004 4:20 pm    Post subject: TOMTOM GPS 3.02 Upgrade available Reply with quote
The above is available on the TOM TOM website, it fixes a problem with the IPAq 2210
MrT
PostPosted: Fri Apr 23, 2004 5:05 pm    Post subject: Reply with quote
TomTom have still failed to fix the locking of the COM port issue. Yet again you need to install this update then uninstall it so that other apps can access the BT com port.
I wonder what will happen if TomTom write an uninstall program that actually uninstalls the GPS?
ianbar
PostPosted: Fri Apr 23, 2004 9:16 pm    Post subject: Reply with quote
So what will happen when using Tomtom traffic (when it is available) with a BT connection to a GPRS mobile phone and BT GPS operating in tandem?
PostPosted: Fri Apr 23, 2004 10:35 pm    Post subject: Reply with quote
TomTom's BT Com Port locking issues affect only the Bluetooth GPS Serial Port, they do not affect partnerships with other Bluetooth devices.
Steveg
PostPosted: Sat Apr 24, 2004 12:36 am    Post subject: Reply with quote
Got to admit I am a little confused now - I have looked at the tomtom website and both the 3.01 and 3.02 updates state that they fix a problem with the ipaq 2210 and intermittent connections with BT GPS.
I have a 2210 and a BT GPS yet I have no problems with connection nor with any locking of the com port as far as I can see - well I didn't until I tried the first update (which I thought was numbered 3.01) and had to uninstall and then re install, and all worked well again.
The question is therefore, is this (3.02) the promised update for 2210 users? If so, should I go ahead with it as I seem to have a functioning product with no problems as such - It isn't broken so would I be silly to attemp to fix it?
Any thoughts would be useful
Steve
alix776
PostPosted: Sat Apr 24, 2004 2:49 am    Post subject: Reply with quote
maybe a rule of thumb is needed if aint broke dont fixit
device Lumia 950 xl
Steveg
PostPosted: Sat Apr 24, 2004 8:01 am    Post subject: Reply with quote
That's basically what I was thinking Alix
It all works and does what I paid for it to do so why about with it and maybe screw something up
Would be interested however to know if this is the update that TT had promised for 2210 owners
Steve
clv
PostPosted: Sat Apr 24, 2004 9:34 am    Post subject: Reply with quote
It's only TomTom GPS that's been updated (to 3.02). Navigator is still at 3.01. But it looks as if they're saying that Navigator 3.01 will now work on a 2210 provided that GPS 3.02 is installed. That's my reading of it, anyhow.
seanm
PostPosted: Sat Apr 24, 2004 10:14 am    Post subject: Reply with quote
The new 3.01 Navigator installs the GPS 3.02 App as its is packaged with it.
Commander
PostPosted: Sat Apr 24, 2004 2:05 pm    Post subject: Reply with quote
OK so let me see if I understand this right. I have a 2210 with TT BT receiver; I order the update, I get Navigator 3.01 which will install GPS 3.02 and this will work on my 2210, but . . . .
. . . according to Mr T I then need to uninstall something (I'm not quite sure what, can you elaborate please). Does this involve the regisrty hack I did a while ago which made using the BT receiver so very much better? (see sticky)
And then of course there is the iPAQ ROM update, should I do this? Before updating TT would seem to be a good time, however . . . . . ..
How did a straightforward update get so complicated?
seanm
PostPosted: Sat Apr 24, 2004 3:04 pm    Post subject: Reply with quote
I am not sure, someone else will help.
But the new GPS Driver 3.02 reacts different to previous versions.
I have not had one lockup since the update (2210 User), but every 10 mins or so I hear the signal lock sound (high pitched tone)
Like it drops the connection but reconnects automatically, as if it is pinging the device?????
Not complaining as this is the most stable it has been, more stable than TT2.
hogbreath
PostPosted: Sat Apr 24, 2004 9:26 pm    Post subject: Reply with quote
Are we back to using Gps 2.07 with ttn 3.02 upgrade:-
When the 3.01 update came out I loaded the Gps driver into ttn2.24 to try it out, it wasn’t any different to Gps 2.09 in that you had to uninstall once to kick start it……..but it worked ok, so I guess Gps 2.07 will work with 3.02 upgrade Question
Pete
MrT
PostPosted: Sun Apr 25, 2004 7:43 am    Post subject: Reply with quote
What I was referring to is that the TomTom GPS application, even when it is not running takes control of the bluetooth serial com port. If you have any other application that wants to use this port, it cannot. The solution that allows other applications to use the port is to go into the PDA settings, remove programs and to uninstall the "TomTom ~ GPS". This does not actually uninstall the TomTom GPS application, it remains there and still works, but it allows other applications to access the port.
22.062 (12 Jun 24)
