Pocket GPS World :: View topic - Calibrating via MM Navigator
mhb
PostPosted: Mon Dec 17, 2007 11:53 am    Post subject: Calibrating via MM Navigator Reply with quote
I am trying to scan in and calibrate part of a 'Cartografia Militar De Espana' 1:50000 paper map. However the Lat/Long is based on a Euro datum (presumed to be Euro 50 although this is not stated on the map).
My problem is that I have no idea how to tell the calibration window that the datum is Euro 50, rather than the default WGS84 which MM seems to assume. The obvious way would seem to have been via 'position format' from the 'Mode' menu but this does not list Euro 50 and selecting 'Other Grid' opens a Windows file locating/opening window for a purpose which I fail to understand.
Any help or advice would be much appreciated.
mhb
PostPosted: Sun Dec 23, 2007 8:10 am    Post subject: Reply with quote
For the record, I find that there is no direct 'in program' way to input Euro 50 datum coordinates but there are websites which offer conversion to WGS84 coordinates. These converted coordinates can then be put into MM to effect calibration of the scanned map. Judging from a comparison between such a calibrated map and results from 'Google Maps' (which give coordinates based on WGS84, of course) for the same area, the coordinates seem to match pretty closely.
The 'Other' option from the MM 'Mode' option apparently affords the ability to load in 'calibration files'. However I have been unable to find out what form these should take so cannot use the facility.
7andy
PostPosted: Fri Jan 04, 2008 1:29 pm    Post subject: Reply with quote
I had the same issue with a Swiss Topo 1:25000 map. The Swiss co-ordinates are, apparently, wildly out. After I used the converter at SwissTopo, the map georeferenced to within a metre!
Very impressive...
mhb
PostPosted: Sat Jan 05, 2008 8:59 am    Post subject: Reply with quote
That's great news as I will not be able to check my maps on the ground, so to speak, until the summer when I will visit Spain.
I have, however, had good results from scanning OS maps here, with the added advantage of scanning at 600 dpi (rather more than original MM OS maps) which enables zooming in to a much greater degree so making the PDA small screen in bright light rather less of a problem.
7andy
PostPosted: Sun Jan 06, 2008 5:46 pm    Post subject: Reply with quote
After I scanned mine in, I checked them against Google Earth. I took a Lat/Long reading from MM and input this into 'earth to see how closely they lined up. Surprisingly accurate actually.
7&Y
inspiredron
PostPosted: Tue Apr 08, 2008 11:14 pm    Post subject: Reply with quote
For a recent trip to Lanzarote I downloaded a map from the web, resized it upwards using Irfanview and then calibrated it using visual matches with Google Earth with surprisingly good results. I calibrated using around a dozen points.
22.062 (12 Jun 24)
