alix776 Pocket GPS Moderator
Posted: Mon Dec 10, 2007 10:00 pm Post subject: T-Mobile uk release uk rom update for MDA Compact III |
over the last week or so T-Mobile uk have quietly released a ROM update for the MDA Compact 3 this follows O2 UK's updat a few months ago
the upside of this is that you can now benefit from this upgrad whitch is free.
the down side to this is that unless you have recnly syncronized or backed up your device (via Activesyn or Windows Mobile Device Centre )you will loose all the data on.
any one using copilot 6 or copilot 7 will need to deactiveate the application at http://activate.alk.com/ALKLicense/web/ALKDeactivation.aspx
Once deactivated you will be able to install the you copilot application again
I have done this to both my own and Teady_bears compact3 and both units are running fine also one main advantage to this update is you will be able to install an update separatly to you device that should enable sd cards upto 8gb to be use ( note i havent tried this yet so im not sure what size card you will be able to use) . the cab file installation may require a hard reset so it it would be wise to install it after the update but before puttting any data on the device this is available from xda-developers.com you will have to serch for it though
there forum.
here is the link for the wm6 T-Mobile MDA Compact 3
this update is available
here _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Tue Dec 11, 2007 5:35 pm Post subject: Re: T-Mobile uk release uk rom update for MDA Compact III |
you can deactivate CP7 within the software itself:
menu / settings / (next) / (next) / licensing / deactivate
MaFt |
Posted: Tue Dec 11, 2007 7:14 pm Post subject: |
I have had no problems with this ROM upgrade and have been using it for a few days, not much difference to be honest but the SDHC support (via a plug in CAB file is very handy, I will be picking up a 6GB card on Friday/ Saturday to try this bit out) - Mike |
Posted: Tue Dec 11, 2007 8:12 pm Post subject: |
mikealder wrote: | I have had no problems with this ROM upgrade and have been using it for a few days, not much difference to be honest but the SDHC support (via a plug in CAB file is very handy, I will be picking up a 6GB card on Friday/ Saturday to try this bit out) - Mike |
so, is it worth upgrading if i never plan on sticking an hdsd card in it?!
MaFt |
Posted: Tue Dec 11, 2007 8:19 pm Post subject: |
No real differences in terms of usability other than you get some anti virus software (why?) so I guess not, the responsiveness of the device is much better, but then again it is clean with none of the rubbish loading it down that I had installed prior to the upgrade.
The big issue with upgrading this ROM seems to be software authentication, Co-Pilot seem to have it covered but TomTom and Route 66 both have issues with the TTN6 device codes once upgraded so be aware of this potential problem, Route 66 supports WM6 according to their web site so its not an issue, TomTom on the other hand do not support WM6 currently so tread carefully, if it isn’t broke don't fix it applies here - Mike |
Posted: Wed Dec 12, 2007 11:22 am Post subject: |
took the plunge
no problems, copilot deactivated and reactivated no problems.
does seem faster especially with regards to file browsing.
MaFt |
theripper Pocket GPS Verifier
Joined: Feb 07, 2006 Posts: 581 Location: Medway Towns, Kent
Posted: Wed Dec 12, 2007 11:14 pm Post subject: |
WARNING
Took the plunge with this yesterday evening put all my software back on my phone and today could not retrieve my voicemail.
Rang T-Mobile support and spoke to a techie who, when I told him I had upgraded to WM6 told me that he didn't hear that as T-Mobile UK did NOT support the upgrade.
Told him that I was not happy as I had downloaded it from their website and he told me that it was going to be removed and he would be speaking to his manager tomorrow to see what can be done.
theripper |
Posted: Thu Dec 13, 2007 12:51 am Post subject: |
tmobile dont support it yet they create the rom with their branding and distribute it via a tmobile-copyrighted site?!
my voicemail works fine - had one earlier! i initially thought my data connection was messed up but i had set up email to use the wrong connection (don't ask...!)
MaFt |
pilk Occasional Visitor
Posted: Fri Jan 04, 2008 12:10 am Post subject: t-mobile mda vario rom update |
i too have just updated my mda vario (slow version!) and it appears now that it cannot connect to my tomtom ONE XL via bluetooth. the bluetooth works on the phone with other gadgets, and i presume the tomtom hasn't changed. so i conclude that the rom update has created a virtual 'new phone' for the tomtom. the rom update has an improved stereo bluetooth 'stack' on it, as there was always a problem with the older roms that they wouldn't drive stereo headphones. it now does that, but has lost my tomtom! could it be that i somehow need to wipe off all traces of my original phone from my tomtom and try to reconnect it form scratch? i've run the flash clear utility, but can't find anywhere to 'remove a phone' on my tomtom.
hmm...... i've asked tomtom about this, but no reply so far......
i did download the new w europe map version 7xx which just managed to cram itself onto my tomtom after i had lightened the ship by jettisoning any unnecessary items, such as all the voices except for Jane, all itineraries, etc etc. does making a new bluetooth connection involve much memory space?
'Lost at sea!'
Posted: Fri Jan 04, 2008 7:30 am Post subject: |
The DUN profile is missing from the BT stack on the phone, go to This Page and download the CAB file, put it straight on to the device's memory card then use File Explorer on the MDA to locate the CAB file, tap it to start the installation - Mike |
Posted: Fri Jan 04, 2008 2:57 pm Post subject: |
mikealder wrote: | The DUN profile is missing from the BT stack on the phone, go to This Page and download the CAB file, put it straight on to the device's memory card then use File Explorer on the MDA to locate the CAB file, tap it to start the installation - Mike |
cheers mike |
Posted: Fri Jan 04, 2008 3:06 pm Post subject: |
hmm... says it cant be installed as it's not got a signed certificate or something... |
Posted: Fri Jan 04, 2008 3:21 pm Post subject: |
Just answer YES when it asks about installing and it will work, I have just tried downloading the file again, puting it on the C-III and running the CAB from File Explorer on the device and it installed fine, I think we are both running the same WM6 ROM and Pointui?? - Mike |
Posted: Fri Jan 04, 2008 4:52 pm Post subject: |
i didn't get an option for yes!! tried again and it went fine...
MaFt |
Posted: Fri Jan 04, 2008 7:16 pm Post subject: mda vario |
i tried the wm6 dun download myself, even tho i only have wm5 but it didn't work. any further suggestions? and i'm still waiting for tomtom to reply. |
