Pocket GPS World :: View topic - tomtom bmp's and ov2's will not paste into ipaq rx5900
dougttt
PostPosted: Sat Dec 01, 2007 7:44 pm    Post subject: tomtom bmp's and ov2's will not paste into ipaq rx5900 Reply with quote
Beginners woes.........I managed to get the speed camers database into the ipaq last month, but the latest files will not paste into the western europe folder, the paste option just greys out. How can I update??
philpugh
PostPosted: Wed Dec 05, 2007 3:20 pm    Post subject: Re: tomtom bmp's and ov2's will not paste into ipaq rx5900 Reply with quote
Check that the card isn't write protected. If you have a separate cardreader try this instead - it's a lot faster.
Failing that eject and re-seat the card.
Phil
spile
PostPosted: Thu Dec 06, 2007 9:19 am    Post subject: Reply with quote
First make sure hidden folders are not ticked (see other threads on this - search for rx5935)
Using Activesync check the filepath...
My Windows Mobile-based device ... Ipaq file store ... IPAQ GPS ... Western_Europe
Then drag and drop the files in there.
dougttt
PostPosted: Thu Dec 06, 2007 9:50 pm    Post subject: Reply with quote
there is no SD card. i installed the files last month following the method on the threads, showing hidden files etc and it worked. only now i want to update i cannot paste the files in, it is greyed out of options pop up window.
spile
PostPosted: Fri Dec 07, 2007 11:20 am    Post subject: Reply with quote
Did you follow my advice above?
dougttt
PostPosted: Fri Dec 07, 2007 11:48 am    Post subject: Reply with quote
bl, yes but i accessed thro My Computer as i can't find Activesync on desktop or anywhere else, but i know it's installed!!
PostPosted: Fri Dec 07, 2007 12:30 pm    Post subject: Reply with quote
Are you using Vista, or XP?
For Vista there's a different program called Windows Mobile Device Centre.
In both cases if they are installed they should open a communications window on the PC screen.
Why not re-install it anyway Idea
dougttt
PostPosted: Fri Dec 07, 2007 2:18 pm    Post subject: Reply with quote
i am using XP. I have now accessed ipaq through Activesync, but the result is the same. The paste option greys over when i try to copy files into Western Europe folder: \iPAQ File Store\iPAQ GPS\Western_Europe
philpugh
PostPosted: Mon Dec 10, 2007 5:20 pm    Post subject: Reply with quote
Still sound like a protection mechanism. Something must be write protected.
Can you copy ANY file to the folder?
Can you copy a camera file to any other location on the device?
Using the Mobile Device on your PC with the iPaq attached - right click on any of the camera files - select Properties... Although they are greyed out you can see the attributes for the file.
Just a last (slightly off-the-wall) thought. Do you have to delete the existing files before you can 'replace' them? I know this isn't usual for these sorts of devices....
Phil
dougttt
PostPosted: Tue Dec 11, 2007 10:57 am    Post subject: Reply with quote
Yes I can copy other files to the folder.
No I cannot copy a camera file to any other location on the device.
Weird?
spile
PostPosted: Tue Dec 11, 2007 12:34 pm    Post subject: Reply with quote
It sounds as though you are trying to copy the files from an open ZIP file.
Copy the files from the zip folder to your desktop (or My Documents) and then drag and drop them from there to your PPC.
dougttt
PostPosted: Mon Dec 31, 2007 12:07 pm    Post subject: Reply with quote
bl, bingo, thanks, we got there!!! much appreciated
22.062 (12 Jun 24)
