Andy_P Pocket GPS Moderator
Posted: Thu Nov 29, 2007 10:31 pm Post subject: Copying Favourites no longer works? |
The regulars here will know that the way to get your Favourites and Home Location has always been to copy the MapSettings.cfg file from your old map folder into the new one.
However, when I did that a few months ago from a Go300 to my new Go720, the TTS voices and speech recognition stopped working. At first, I wasn't convinced that what I'd done was the problem, but over the last few weeks I've heard a few more people having the same issue.
Now today, I copied a MapSettings.cfg file from a Go700 v6 to the same machine with new maps and v7, and it wouldn't boot past the splash screen. Putting the "proper" version of the file back cured it straight away.
So, it seems the MapSettings.cfg files are not compatible across versions anymore. |
TvrForever Occasional Visitor
Posted: Fri Nov 30, 2007 6:42 am Post subject: |
Quote: | Now today, I copied a MapSettings.cfg file from a Go700 v6 to the same machine with new maps and v7, and it wouldn't boot past the splash screen. Putting the "proper" version of the file back cured it straight away. |
I've had exactly the same issue with copying Mapsettings.cfg fro a v6 map to a v7 map - running on the current v7 software on my TTG700.
Very frustrating as I've now lost all of my favorites ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
Oldboy Pocket GPS Moderator
Posted: Fri Nov 30, 2007 7:47 am Post subject: |
If you open the old MapSettings File with POIEdit, you should be able to identify the locations of your Favourites.
Just delete everything else there, mainly Recent Destinations, and save as a TT OV2 File. If you see a duplication, you can remove either.
Copy this to your Map Folder as a Favourites POI. _________________ Richard
46jimbo Regular Visitor
Posted: Fri Nov 30, 2007 12:45 pm Post subject: |
Or convert your Favourites to POIs. |
Posted: Fri Nov 30, 2007 6:22 pm Post subject: |
46jimbo wrote: | Or convert your Favourites to POIs. |
Too late to do that if he's already removed the old map to make way for the new one.... (unless he uses Oldboy's suggestion)
Thanks for the heads up on POI Edit, Oldboy. I'd forgotten that it can open the .cfg file now.
I was in exactly that situation with my work colleague's new map on a Go700.
We had removed the old map already, and (too late) I confirmed my suspicions that copying MapSettings.cfg doesn't work any more.
Popped it into POI Edit and Bingo! One happy workmate ![Thumbs Up](modules/Forums/images/smiles/custom2.gif) |
mpwilson99 Lifetime Member
![](modules/Forums/images/avatars/15509806134a81c3cd19d71.jpg)
Joined: Jun 30, 2007 Posts: 462 Location: Hickstead, Sussex
Posted: Tue Dec 04, 2007 12:14 pm Post subject: |
Sadly its not just the favs that go, im sure all my POI sound and distance settings went along with it.
Found that out when i got my TT720 back in August.
It is really bad that they didnt keep this compatability between versions.
Thanks |
Posted: Tue Dec 04, 2007 4:06 pm Post subject: |
Think of it from their point of view though... If they invent new functionality (like using the text to speech voices as POI warnings with your own message!) then its a bit hard to keep the file completely compatible with old versions where it didn't exist. |
5lab Occasional Visitor
Posted: Tue Dec 04, 2007 4:19 pm Post subject: |
you seem to have to fire up the tomtom via your computer first - this happened to me when i copied my favourites over - not getting past the splash screen. then i remembered a forum thread from ages ago - connect it back up to your computer, use the control your tt option, and it seems to work after that fine! |
Posted: Tue Dec 04, 2007 6:04 pm Post subject: |
5lab wrote: | .... then i remembered a forum thread from ages ago - connect it back up to your computer, use the control your tt option, and it seems to work after that fine! | In others words ..... do a Reset. ![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Richard
Posted: Tue Dec 04, 2007 6:16 pm Post subject: |
nah, resetting mine with a pin didnt work, still crashed on startup. once plugged in and started it worked fine.
:P |
DennisN Tired Old Man
![Tired Old Man Tired Old Man](modules/Forums/images/ranks/moderator.gif)
![](http://maft.co.uk/avatars/dennis.jpg)
Posted: Tue Dec 04, 2007 8:07 pm Post subject: |
Andy_P2002 wrote: | Too late to do that if he's already removed the old map to make way for the new one.... |
He must have had a load of stuff on the 700 - that hard disk was big enough for me to have three Western Europe maps on it, IIRC (definitely two). _________________ Dennis
Two of them are obesiting!! |
Posted: Tue Dec 04, 2007 8:10 pm Post subject: |
Sorry, forgot to add that I'm using the MapSettings.cfg that I brought from my 700, to my 710, to my 720. Just copied the map v705 cfg file to the v710 map tonight. _________________ Dennis
