Ollie_GBR Occasional Visitor
Posted: Fri Nov 30, 2007 10:36 am Post subject: Zumo & Google Earth |
I understand you can upload your track log to Google Earth on the Zumo, can someone please explain how?
Ollie |
Skippy Pocket GPS Verifier
![](modules/Forums/images/avatars/7197988194d2507f52befb.jpg)
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Fri Nov 30, 2007 4:03 pm Post subject: |
If you have Mapsource, the newer versions have a menu option: View -- View in Google Earth which imports waypoints and tracks straight into Google Earth.
Can't work out how to make it fly though? Any pointers? _________________ Gone fishing! |
Brian Regular Visitor
![](modules/Forums/images/avatars/229614284480a67e8f1706.jpg)
Joined: Nov 12, 2003 Posts: 94 Location: Lancashire, England, Great Britain
Posted: Fri Jan 25, 2008 9:52 pm Post subject: |
Yes! after opening in Google Earth, look at the left hand side of the screen for 'Temporary Places', expand this until you find an icon with 'three connected spheres', select this and click the 'play' icon below. _________________ Aprilia Tuono, Zumo 550
Ipaq 2210/Fortuna/TomTom Nav6
& Road Angel 7000 + Memory Map |
desd Regular Visitor
![](modules/Forums/images/avatars/104513279447c71089d8935.jpg)
Posted: Thu Feb 28, 2008 5:10 pm Post subject: |
Tried this but any route I import it just joins the waypoints with straight lines is there anyway to make it recalculate the route?? or do I just need to recreate the route and let it do it that way. _________________ Zumo 500 + 4GB SD Card, car Kit and GTM21
Linked to Autocom by bluetooth and all seems good.
Traffic reception in the central belt of Scotland and hurray NW England seems to be working again. Still a million times better than the Quest 2 it replaces |
Posted: Thu Feb 28, 2008 9:26 pm Post subject: |
desd wrote: | Tried this but any route I import it just joins the waypoints with straight lines is there anyway to make it recalculate the route?? or do I just need to recreate the route and let it do it that way. |
The waypoints you see are the turn points. In between them you follow the flow of the road. Google Earth will just show these as straight lines between each turn...
I can't really think of any way around this - you could add a load of extra waypoints along the route. Tracklogs display OK because there are loads of points in them... _________________ Gone fishing! |
Posted: Fri Feb 29, 2008 10:21 am Post subject: |
I realise this I just hoped there was an option like with Mapsource to recalculate route _________________ Zumo 500 + 4GB SD Card, car Kit and GTM21
bumpkin Frequent Visitor
Joined: Feb 08, 2006 Posts: 264 Location: Herefordshire
Posted: Fri Feb 29, 2008 3:56 pm Post subject: |
I don't know what version of Mapsource you're using but with mine it follows the route faithfully.
I'm using Mapsource 6.13.4 and Google Earth 4.2.0205 _________________ Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10 |
Posted: Fri Feb 29, 2008 6:57 pm Post subject: |
I'm using mapsource 6.11.5 as that's what came with my Zumo.
I have the same version of Google earth so I'm not sure what difference the newer version of mapsource does unless it actually tells Google earth what the route planned was? _________________ Zumo 500 + 4GB SD Card, car Kit and GTM21
Posted: Fri Feb 29, 2008 8:34 pm Post subject: |
desd wrote: | I'm using mapsource 6.11.5 as that's what came with my Zumo. |
Could well be the KML file produced by Mapsource having sufficient attributes to show the route in detail, that would require a more current version. You can either use the 'check for software updates' in the Help menu or to be bang up to date go here. Using the former method with my v 6.13.4 says no update available yet the one at the URL above is 6.13.7. _________________ Chas
Posted: Sat Mar 01, 2008 12:33 pm Post subject: |
I did the auto update and now when I export a route it shows the route not just the waypoints ta fellas _________________ Zumo 500 + 4GB SD Card, car Kit and GTM21
