Pocket GPS World :: View topic - Battery Related Information
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
kidstypike
PostPosted: Wed Nov 21, 2007 8:01 pm    Post subject: Reply with quote
mikealder wrote:
This is a known issue that you are told about when you open the box, I simply remove a cell when I don't need to use the unit - only once have I forgotten and flattened a new(ish) set of Lithium cells - Mike
You are told about this issue when you spend 300 sheets, and open the box? Never mind, maybe you can download a simple on-off toggle switch from their website in the near future!!!
kidstypike
bryanwal
PostPosted: Thu Nov 22, 2007 6:46 pm    Post subject: Reply with quote
regarding the battery issue i leave my 2700 mah rechargables i my active 10 with no probs .last used unit sunday gone ,checked tonite and meter still showing 4 bars
bryanwal
PostPosted: Wed Nov 28, 2007 7:41 pm    Post subject: Reply with quote
guess what its still on 4 bars, is every body sure they are switching unit off properly
nataliej
PostPosted: Thu Nov 29, 2007 12:51 pm    Post subject: Reply with quote
I have checked mine and it still has ample battery life!!
robs1972
PostPosted: Thu Nov 29, 2007 7:46 pm    Post subject: Re: Satmap Active 10 Reply with quote
merroarc wrote:
My earlier problem with freezing screen etc was cured by slightly tightening (with advice from Satmap team) the battery contacts.
Can you explain that a little more? Many of my freezes have occurred when stationary...not sure how it could be a battery contact issue.
I like mapping, I like mapping, I like mapping and I like to map!
merroarc
PostPosted: Thu Nov 29, 2007 8:32 pm    Post subject: freezing Reply with quote
My freezing problems happened when I put new batteries in first time, I could only un-freeze the device by taking the batteries out and re-inserting them, twice.
Since then it has happened when on the move on the bike. I felt this was due to loose or not sufficiently tight batteries jiggling about inside the unit. I spoke to Satmap who said I could carefully tighten the battery terminals to improve the fit.
Have you got version 1.03 software ? This seems to help all sorts of issues.
Speak to Satmap, I have found them really helpful.
Cheers,
Simon
PostPosted: Fri Nov 30, 2007 3:57 pm    Post subject: Reply with quote
If you intend carrying fully charged high power cells around you should consider a box that not only keeps the cells safe but prevents them from shorting out and getting very hot, I use one of These - Mike
merroarc
PostPosted: Fri Nov 30, 2007 4:30 pm    Post subject: Satmap Active 10 batteries Reply with quote
Hi Mike,
Thanks for that. I'm currently carrying 3 NH batteries in the front pouch of the carry case. I don't think they will short out, but I'll take extra precautions.
Is it an issue to leave them in the unit fully charged ? I've noted Robs problem although I think he might have a particulat problem.
Thanks,
Simon
PostPosted: Fri Nov 30, 2007 4:34 pm    Post subject: Reply with quote
The unit does draw current from the batteries even when switched off, over a few days this can flatten the cells - I usually remove batteries from my active 10 when it is not in use (most week days etc, work gets in the way of walking!) - Mike
bryanwal
PostPosted: Fri Nov 30, 2007 7:36 pm    Post subject: Reply with quote
as stated earlier mine's now had batteries in for over a fortnight and still on 3 bars
robs1972
PostPosted: Mon Dec 03, 2007 1:15 am    Post subject: Reply with quote
I've had mine show 3 bars for several hours before going straight to Battery Critical.
PostPosted: Tue Dec 04, 2007 7:22 pm    Post subject: Reply with quote
I think another accessory SatMap could consider is a bike mounted power pack, similar to the type used for the high power lights. I recently built a new battery pack for a mate using very high capacity D size rechargable cells, at 13,000mAHr it would power an active 10 for 35+ hours from a single charge on full back light with no power off.
The cells fit in a water bottle style carrier, they are not too heavy all that is required is the connector and replacement back cover - I would even consider this a viable addition to the rucksack for a longer walk over 3 or 4 days - Mike
PloddinPedro
PostPosted: Tue Dec 04, 2007 7:42 pm    Post subject: Reply with quote
That's a good idea, although my preference would be for something that mounted underneath the stem or possibly under the top tube, behind the head tube (although I acknowledge that the latter works best on larger frames.) I prefer to reduce cable clutter and I like to use all my bottle mounts for drink! As for attaching it to the Satmap, perhaps the USB port might be a possibility? It would need effective sealing of course.
robs1972
PostPosted: Wed Dec 05, 2007 4:36 pm    Post subject: Reply with quote
What kind of batteries are you using where you only get 4 hours? Shocked
I did 95 miles on the road, around Dartmoor, with the screen on 70% all the time, no faffing with any powersaving, with a bit of scrolling around every now and then and I didn't turn it off at my sandwich stop so we are talking at least 7 hours from freshly charged 2500s
What this device has seen me do though, is buy a battery charger that can do 1,2,3 or 4 batteries at a time with voltage detection rather than the usual 2 or 4.
merroarc
PostPosted: Wed Dec 05, 2007 5:14 pm    Post subject: batteries Reply with quote
Hi robs1972,
I'm using NiH rechargeables and a 1 hour charger.
I've not run the device for more than 4 hours, but it did drop a bar at just before 4 hours. This was screen on all the time at 40% and it was around 2 degrees C. I think low temps have a large effect.
Thanks,
merroarc
Page 3 of 8
22.055 (29 May 24)
