Snudge Lifetime Member
Joined: Aug 22, 2007 Posts: 211 Location: Peterborough
Posted: Fri Nov 23, 2007 6:35 pm Post subject: |
Thanks for the detail Oldboy but you’ve lost me here – I’m a novice so a few questions please.
1) What is the ‘stay resident’ portion?
2) What is the ‘root’ of the card?
3) How do I reinstall the software? (obviously I can format the card and replace everything from my backup but I lose all the settings so I'm assuming you mean something different?)
Thanks. |
rbecking Occasional Visitor
Posted: Fri Nov 23, 2007 6:55 pm Post subject: |
I've found I've got this problem too with 7.161 and 2gb extreme sd card. Will try this full reset. |
Oldboy Pocket GPS Moderator
Posted: Fri Nov 23, 2007 7:02 pm Post subject: |
Snudge wrote: | so a few questions please. |
1: Terminate and Stay Resident programs load the program from a Storage media. When the program/Device is switched off a portion of the program stays in memory. When it starts up the next time it doesn't have to go though reading everything from the Storage Media, but reads it from the much faster RAM. Some programs can save several seconds by doing this.
2. The Root of the SD Card is the highest level on the Card. In Explorer it will have a Drive Letter, and named TomTom. It will have files like system, ttsystem and the Main Folders, like the Maps and Zip.
3. The files that are the most important are:
system
ttsystem
libaec.so
install.bif
If you backup the Files in the Root only, (I've got about 30 ) before deleting, it will be your insurance. Then use HOME to install the software again. _________________ Richard
Posted: Fri Nov 23, 2007 8:55 pm Post subject: |
Thanks for help Oldboy - so have I got this right? In my pic I delete all the files in the right-hand pane and also the folder called TomTomHomeInstall.app. I then copy the files that I deleted from my backup, connect to Home and it will download the app again?
wibbly Frequent Visitor
Posted: Fri Nov 23, 2007 9:25 pm Post subject: |
xda wrote: | Not sure about the latest versions of Home as I don't use it for backups, but with earlier versions it was reported that it didn't backup all the files and directories. As such it was not able to do a full restore. |
Well for what it's worth I reformatted the SD card after backing it up (manual and via Home 2) and chose to restore it via Home 2. Seems to have worked fine. |
Posted: Fri Nov 23, 2007 10:02 pm Post subject: |
Snudge wrote: | Thanks for help Oldboy - so have I got this right? In my pic I delete all the files in the right-hand pane and also the folder called TomTomHomeInstall.app. I then copy the files that I deleted from my backup, connect to Home and it will download the app again? | Not quite. Copy the files to the PC, before you delete them.
You can leave the HOMEInstall Folder where it is.
When you connect to HOME go to Add Maps Traffic etc. and on Page 3 of 3 will be Items on my Computer.
Click the "+" by Applications and it should show your previous download. Just Click the appropiate Add button. _________________ Richard
lola Lifetime Member
Posted: Sat Nov 24, 2007 11:55 am Post subject: |
a wrote: |
Hope this helps. |
Thanks - I think so but just when I thought I was getting the hang of things – I think I’ve missed something?
Oldboy, you agree that I delete all the files in the right-hand pane shown in my pic but then say I should first back them up. I thought the whole point of deleting those files was because they may be corrupt so there’s no point in backing-up those files is there? I already have backed-up everything before I used the device anyway using Win Explorer.
a wrote: | Keep ALL yellow folders but delete everything else. You will then have deleted the existing application. Now reinstall the version 7.161 software again. |
This advice sounds like installing app 7.161 will install the deleted files so is this what you mean when you say:
Oldboy wrote: | Click the "+" by Applications and it should show your previous download. Just Click the appropiate Add button |
I want to understand what I’m doing here rather than just press buttons – I’m a mechanical engineer so understand nuts and bolts but I struggle a bit with this stuff.
Thanks for help. |
Posted: Sat Nov 24, 2007 12:19 pm Post subject: |
Snudge wrote: | I already have backed-up everything before I used the device anyway using Win Explorer. | That will do then. It was just a safety net if you needed a particular file.
Snudge wrote: | a wrote: | Keep ALL yellow folders but delete everything else. You will then have deleted the existing application. Now reinstall the version 7.161 software again. |
Oldboy wrote: | Click the "+" by Applications and it should show your previous download. Just Click the appropriate Add button |
| Yes, and this should put the correct files on the Unit. _________________ Richard
Posted: Sat Nov 24, 2007 12:58 pm Post subject: |
Thanks Oldboy - I think I've got it now. |
rap Occasional Visitor
Posted: Sat Nov 24, 2007 8:21 pm Post subject: Re: SD problems since 7.161 patch |
GerryC wrote: | wibbly wrote: | Now the TT randomly fails to start (the on buttin has NO visible effect). If I pull the SD card it starts and I can reinsert and then it runs fine. Until the next time. As the card worked to start I can only imagine a driver update in the lastest firmware in the TT has created a problem?
Anyone else seen this or have any advice? |
Exactly the same thing happened to me when I put 7.161 onto the XL.
If you do a full reset, it fixes the problem.
[u][u]Make sure device is fully charged - remove SD card - press reset button for 15 seconds - turn on - replace SD card. | [/u][/u]
Had same problem after downloading update, did as above via reset now sorted |
Posted: Sat Nov 24, 2007 8:27 pm Post subject: |
Full reset seems to have sorted for now. Time will tell I guess...
Thanks all |
Steven0161 Occasional Visitor
Posted: Sat Nov 24, 2007 11:32 pm Post subject: Re: SD problems since 7.161 patch |
wibbly wrote: | I now use an Extreme III 2GB card in a TT1 V2. It has worked fine.
Same Problem here must be a bug as I also have a Extreme III 2GB card in a TT1 V2 |
traffic_doc Occasional Visitor
Posted: Wed Nov 28, 2007 4:52 pm Post subject: Full reset worked for me as well |
I have the TT1 New Edition and after the update was unable to turn it on without having to remove/reinstall the SD Card.
Using the guidance found here on doing the hard reset, the problem has gone away.
Thanks!! |
Posted: Wed Nov 28, 2007 5:37 pm Post subject: |
Full reset has worked for me too :-) Thanks for the advice. |
