BAVC10 Lifetime Member
Posted: Tue Nov 13, 2007 11:15 pm Post subject: Nuvi 6XX Firmware update - 4.20 |
Garmin have just released 4.20.
Upgrade looks worth doing if it actually does make the map refresh quicker.
Changes made from version 4.10 to 4.20:
Improved the map drawing speed.
Corrected issue with proximity points in areas with many roads causing the map to draw slower.
Corrected issue where all traffic delays were represented as 1 minute. |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Fri Nov 16, 2007 10:00 am Post subject: |
Seems to be a bit crisper redrawing maps. Also - and this has only been checked on a short journey into work this am - the lag when not following a route doesn't seem as bad as it can do - but need to try it over a longer drive to be sure. _________________ Phil |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Fri Nov 16, 2007 12:37 pm Post subject: |
I've heard rumours that a reset of the device can speed things up too - so it might be that the firmware update naturally resets the device, which could explain the speed up. I guess the interesting point is to see if it remains faster after a few weeks... _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Mon Nov 19, 2007 8:59 am Post subject: |
Firmware 4.20 seems to be pretty stable and has definitely speeded up the map refresh rate as well as making the zoming in at junctions a bit more logical.
Only slight bug seems to be when you tap the "next turn" box it doesn't always display your next turn (just the full map screen).. |
madhatter Regular Visitor
Posted: Tue Nov 20, 2007 7:15 pm Post subject: |
If you listen to mp3's and have the pocket gps speedcamera database with mp3 voice files the 4.20 update will cause problems. It causes the mp3 to skip to the next track when the voice speedwarning goes off. Garmin are looking for another firmware update and have said they may pull the 4.20 update. |
