mark1968 Frequent Visitor
Joined: Mar 01, 2004 Posts: 290 Location: Northampton
Posted: Fri Oct 19, 2007 7:34 am Post subject: Own Pois in I-Go |
I have a number of sub groups set up as pois, but have been unable to edit a saves poi into the correct category.
I follow the edit poi process select ok at the end and the poi sits in the last category used not the one selected.
Does anyone know where they are kept and if we can edit then ouside of the program? _________________ Please follow me on twitter @mdyson1968 |
Border_Collie Pocket GPS Verifier
![](modules/Forums/images/avatars/846718549526d5fd14b726.jpg)
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Oct 19, 2007 4:36 pm Post subject: |
A straightforward Edit and changing Group can put the POI's in the wrong group but the following works for me.
Select POI - Edit - Select Group - arrow back, then click OK. |
Posted: Fri Oct 19, 2007 5:45 pm Post subject: |
Thanks that'swhat I have been doing, the poi changes into the correctgroup until I exit the prog normally. When I go back in the poi has reverted back to its original group. _________________ Please follow me on twitter @mdyson1968 |
Posted: Fri Oct 19, 2007 6:11 pm Post subject: |
Quote: | Thanks that's what I have been doing, the poi changes into the correctgroup until I exit the prog normally. When I go back in the poi has reverted back to its original group. |
I may have missed out an instruction.
POI - Edit POI - Change Group - Tap on POI Name then Done. Tap arrow - Tap OK. |
Posted: Fri Oct 19, 2007 8:39 pm Post subject: |
I have tried that as a solution but again as soon as I exit the progran, the POI resets back to the origional group. _________________ Please follow me on twitter @mdyson1968 |
Posted: Fri Oct 19, 2007 9:06 pm Post subject: |
Quote: | I have tried that as a solution but again as soon as I exit the progran, the POI resets back to the origional group. |
It can be done, maybe my memory is playing up.
On first install all my POI Groups stayed as they should but I hard re-set my Mio. I re-installed iGO, after which I found I had the same problem as you are getting.
I 'messed' around experimenting with the Groups and eventually got it right. Problem is, it appears I can't remember what I did.
I'll experiment with mine and try to find out what I did. |
Posted: Sun Oct 21, 2007 9:17 am Post subject: |
I have resolved this issue by ising a free applicatgion called I-GO POI Explorer. This application allows you to edit your POIs on a PC and also import POIs from TOMTOM etc.
The download can be found here http://inetcom.hu/mick/igo/ _________________ Please follow me on twitter @mdyson1968 |
bakerman Occasional Visitor
Posted: Thu Jan 03, 2008 1:00 pm Post subject: |
Has anyone got this i-go poi explorer working, mine bombs out everytime I try and use it. |
