Pocket GPS World :: View topic - Custom Medion 210
Custom Medion 210
Fatslag
Banned
PostPosted: Fri Oct 19, 2007 12:21 pm    Post subject: Custom Medion 210 Reply with quote
Make sure your pc is set to read/see all system and hidden files
My Custom Flash disk Medion AE with lots of funtions not in the basic version, it will run by deleting your flash disk and copying mine over to replace it.
How to, rename audiomanager.exe to xaudiomanger.exe also rename menu.exe to xmenu.exe then delete everything from your flash disk except the setting folder.(contains the medion key)and copy my version over.
The above renamed files can be deleted after a reset.If you get no green bars then reset the unit to factory settings in the medion software menu, then hard reset the unit
This version includes
Poi warnings with sounds
Gopal version 3 AE
Medion Mp3 Player
Windows exsplorer
Complete Maps of europe
Complete travelguide of european all cities
Medion picture viewer
allso map gimmicks ie 3d mode planes take off in the sky
allso car headlights for 3d night driving
allso has route demonstration mode for planned routes
Navigation to poi
Lots more Gopal poi's
Fatboyfun
PostPosted: Fri Oct 19, 2007 8:18 pm    Post subject: Reply with quote
Can you search UK postcodes, Because I have Gopal 3 PE and i can't.
DaveNN
PostPosted: Sun Oct 21, 2007 4:45 pm    Post subject: Re: Custom Medion 210 Reply with quote
Gopal version 3 AE
Medion Mp3 Player
Windows exsplorer
Navigation to poi
Planes??? tell me more pls Gary!!!!
Fatslag
Banned
PostPosted: Mon Oct 22, 2007 11:55 am    Post subject: planes Reply with quote
Yup planes are there when you run the medion in 3d mode day time every few minute you will see a plane take off there is a file called PFSpecial.skn i took this out off the PE version and added it to my custom AE flash disk version
lewie226
PostPosted: Mon Oct 22, 2007 12:19 pm    Post subject: Re: planes Reply with quote
How is this done?
I would really like this on my 210
Fatslag
Banned
PostPosted: Mon Oct 22, 2007 12:28 pm    Post subject: well easyest way is to use my psf.skn file Reply with quote
well easyest way is to use my psf.skn file or manualy edit the one you have like so you need the following files map gimmick plane
170:PPSkin\MapGimmickPlane.png;
and PFSkin.skn which has the following code added
MapGimmick1 //Plane
Class: NStateIconAnimation;
Coordinates: 115,0,185,46;
States: 16;
BitmapReference1: 170,0,0,185,46,0,0;
BitmapReference2: 170,0,46,185,46,0,0;
BitmapReference3: 170,0,92,185,46,0,0;
BitmapReference4: 170,0,138,185,46,0,0;
BitmapReference5: 170,0,184,185,46,0,0;
BitmapReference6: 170,0,230,185,46,0,0;
BitmapReference7: 170,0,276,185,46,0,0;
BitmapReference8: 170,0,322,185,46,0,0;
BitmapReference9: 170,0,368,185,46,0,0;
BitmapReference10: 170,0,414,185,46,0,0;
BitmapReference11: 170,0,460,185,46,0,0;
BitmapReference12: 170,0,506,185,46,0,0;
BitmapReference13: 170,0,552,185,46,0,0;
BitmapReference14: 170,0,598,185,46,0,0;
BitmapReference15: 170,0,644,185,46,0,0;
BitmapReference16: 170,0,690,185,46,0,0;
CyclicRuns: 1;
Visibility: Hidden;
ShowOnMapState: 10;
ShowOnDesignMode: 0;
ShowOnStarting: yo;
HideOnStopping: yo;
DaveNN
PostPosted: Mon Oct 22, 2007 8:45 pm    Post subject: Re: well easyest way is to use my psf.skn file Reply with quote
MapGimmick1 //Plane
States: 16;
CyclicRuns: 1;
Visibility: Hidden;
ShowOnMapState: 10;
ShowOnStarting: yo;
HideOnStopping: yo;
Thanks Gary,
Might be easier to stick to the Vectra Estate for now!!!!
I haven't got the foggiest idea what you are going on about!! Embarassed
As a matter of interest ; would a modded 205 (with PE or AE installed) run TMC??
DNN
Fatslag
Banned
PostPosted: Tue Oct 23, 2007 3:21 pm    Post subject: tmc Reply with quote
There is no TMC on this device mate only on the more exspensive units
baroni701
PostPosted: Fri Nov 02, 2007 11:19 am    Post subject: Reply with quote
Where can I get hold of these files - been looking for a while now and going round in circles - seems most links are now invalid Sad
DaveNN
PostPosted: Fri Nov 02, 2007 5:32 pm    Post subject: Reply with quote
Not too sure...would suggest you pm a few of the bods who have responded to posts such as these.
b1ackb1rd
PostPosted: Fri Nov 02, 2007 6:29 pm    Post subject: Reply with quote
I'd suggest a PM to a member from 'Viz'
DaveNN
PostPosted: Sat Nov 03, 2007 11:06 am    Post subject: Reply with quote
Roger Melley???
22.062 (12 Jun 24)
