Pocket GPS World :: View topic - Help - memory map - arc view
backontrack
PostPosted: Thu Oct 18, 2007 9:46 am    Post subject: Help - memory map - arc view Reply with quote
Hi there, I have memory map OS5 and have been plotting routes and tracks from my pda/gps. Is there any way of exporting my gps data (tracks ets) to someone who is running arcview. I think they usually import shp files? Though I must admit I don't know a lot about this but I really need to be able to send this data to them.
Thanks.
Mortiki_UK
PostPosted: Thu Oct 18, 2007 11:23 am    Post subject: Reply with quote
backontrack,
You will need a Proffesional Licence from Memory-Map in order to import or export .SHP files
Mortiki
Garmin Etrex H
Memory-Map V5 5.2.7
backontrack
PostPosted: Thu Oct 18, 2007 11:45 am    Post subject: Reply with quote
Aha, so with that license is it as simple as to export the file as a shp file from MM and then import it as a SHP file in Arc view? The track will view the same? Can it then be manipulated in arcview?
Mortiki_UK
PostPosted: Thu Oct 18, 2007 11:51 am    Post subject: Reply with quote
Right Click on the Track and select SAVE AS. Change the file type to .SHP. I dont know how it displays once imported into another program though
Garmin Etrex H
Memory-Map V5 5.2.7
JasonMM
PostPosted: Thu Oct 18, 2007 12:11 pm    Post subject: Reply with quote
the earlier advise from Mortiki is correct.
I cannot see why the track would not display the same within ArcView, but I am unsure as to whether you can actually edit teh file once in teh software.
Jason
