Pocket GPS World :: View topic - Please help me - SD card problem with TomTom Europe XL
Fred76
PostPosted: Thu Sep 13, 2007 7:49 am    Post subject: Please help me - SD card problem with TomTom Europe XL Reply with quote
Got my new TomTom XL yesterday with a separate ScanDisk 2Gb SD card. My problem is that when I copy my map content to the SD cartd and insert it ni my TOMTOM it restarts and a red cross coming up. I borrowed a TomTom SD card from a friend and tried, but the same problem occurs.
Does anyone know how to fix this? Isn't possible to by a non-TomTom SD card an use it? Since my friends TomTom card doesn't work either I think there might be something working with my TomTom Sad
Tim Buxton
PostPosted: Thu Sep 13, 2007 8:16 am    Post subject: Reply with quote
You need to copy everything, including any hidden files, to the new SD card.
Tim
Fred76
PostPosted: Thu Sep 13, 2007 8:21 am    Post subject: Reply with quote
So if I make a backup of the content on my TomTom to my new SD card and then insert it, it will work?
Tim Buxton
PostPosted: Thu Sep 13, 2007 8:24 am    Post subject: Reply with quote
It should do if you backup the full content. No promises, though, as my XL is an SD card 'virgin'. I have enough room on the Internal memory for my current needs.
Tim
PaulB2005
PostPosted: Thu Sep 13, 2007 8:57 am    Post subject: Reply with quote
How is it some SD (Secure Digital) cards can be copied and some can't?
I can back up the contents of my TransFlash card in my i3 to my PC but it won't work if copied to a new card......
Tim Buxton
PostPosted: Thu Sep 13, 2007 9:02 am    Post subject: Reply with quote
I think that Garmin tied activation to the card as opposed to a specific device, so they'd put in some sort of card protection, like its serial number, looking specifically for an address marked as 'bad' or something (probably much more cunning) like that.
Tim
PaulB2005
PostPosted: Thu Sep 13, 2007 9:18 am    Post subject: Reply with quote
Ah i see. Thanks.
Fred76
PostPosted: Thu Sep 13, 2007 9:33 am    Post subject: Reply with quote
Hmm..didn't work Sad ..TomTom still doesn't want to read my SD card
PostPosted: Thu Sep 13, 2007 12:04 pm    Post subject: Reply with quote
Keep trying.
It should work, but as with all things computer, it is often very hard to work out exactly what you did differently, when something suddenly works this time!
There are many discussions about this on the forums, and often the thing that people flag up as being the thing that sorted it for them, seems plain daft, but it worked! (or possibly, they did something else at the same time Wink ).
One recurrent theme you could try is doing a reformat of the card. For this, some say it *must* be FAT and others say it *must* be FAT 32, some say it must be done in the TomTom some say it must be done in a card reader (or even in a camera!).
Good luck!
PostPosted: Thu Sep 13, 2007 12:37 pm    Post subject: Reply with quote
You should also consider the read speed of the new card, if its not fast enough the device will reject the card and refuse to boot up, see the FAQ page listed in the sticky threads within this forum for more details on copying the card and the speed related issue - Mike
thestarsshine
PostPosted: Sat Sep 15, 2007 5:17 am    Post subject: Reply with quote
You will need to format the 2 GB SD card.
Then, you'll have to make sure there's the map, the application, and at least one voice on the SD card. TTH isn't known to successfully make and restore back-up's, so manual back-up's work better.
JockTamsonsBairn
PostPosted: Sat Sep 15, 2007 9:34 am    Post subject: Re: Please help me - SD card problem with TomTom Europe XL Reply with quote
Do you mean SanDisk? All the ScanDisks that Google returns are mis-spellings of SanDisk. If SanDisk, what "model" of card? They have various, Ultra II, Extreme III, ..., which, I think, have different read/write speeds.
I've never had to format a SD card, "out of the packet". Is there something special about the format that the new models use?
Jock
PostPosted: Sat Sep 15, 2007 8:12 pm    Post subject: Reply with quote
NO.
I've never had to format any SD card I've used in a TomTom.
bryanbellis
PostPosted: Sun Sep 16, 2007 8:59 am    Post subject: Re: Please help me - SD card problem with TomTom Europe XL Reply with quote
Also, if it is a Sandiskm SD card, is it one of the Ultra II versions?? You need a decent mopdern card reader to read them in the PC, and I don't know if the TomTom is acapable of reafing the UIltra II cards. Anyone?
22.055 (29 May 24)
