Pocket GPS World :: View topic - Fugawi UK 2 on Ique3000
iQue3000user
PostPosted: Sun Sep 09, 2007 1:01 pm    Post subject: Fugawi UK 2 on Ique3000 Reply with quote
Having recently changed from an old Palm M515 with Magellan GPS Backpack to a new IQue 3000 I am having trouble getting fugawi to see the in-built GPS. Fugawi is otherwise installed and working ok on the new IQue.
I am running Fugawi UK Version 2 on the PC (latest update = .1049)
On the IQue it is showing as Fugawi for Palm v 02.01.02
GPS on the Ique works fine with built in QNav software and with cachemate / cachenav but Fugawi simply will not connect.
On the M515 I had com port numbers listed under "port number" options under GPS Prefs menu but on the IQue these are replaced by "Cradle, IR, Console, Cradle232 and CradleUSB"
It defaults to Cradle with a baud rate of 4800 which I think should be the correct settings.
I have tried opening and closing the ports and selecting other ports and baud rate combinations but whatever I try results in the sky info window being completely empty. No satellites listed and no big circle to represent the horizon.
I have tried uninstall - reinstall in case software was at fault but same problem occurs.
Any idea what the correct baud and port settings should be and what else i can do to get the GPS to talk to fugawi ?
alix776
PostPosted: Sun Sep 09, 2007 7:14 pm    Post subject: Reply with quote
you need to select pocketpc not palm
device Lumia 950 xl
