Pocket GPS World :: View topic - Free Memory-Map 2004 Upgrade
Goto page 1, 2, 3  Next
PostPosted: Fri Mar 26, 2004 10:32 am    Post subject: Free Memory-Map 2004 Upgrade Reply with quote
Memory Map wrote:
Memory-Map is pleased to announce a free upgrade for existing Memory-Map 2004 OS Edition users! Customers with Memory-Map 2003 and previous versions can purchase a discounted upgrade by clicking here.
Just some of the new features in this update include:
3D Fly Through – 3D-View™ takes off with the all new Fly mode. Just right click on a Route or Track and you'll be transported to 3D-View and automatically flown along your path. When used with aerial photography the results are breathtaking.
Relief Shading – Print maps with the new Relief Shading options and you'll see 3D terrain on an accurate printed map.
User icons - Import your own icons into Memory-Map and use them anywhere on your maps. Coupled with Memory-Map's improved Overlay management feature, the possibilities are endless!
In an unprecidented move the upgrade for MM2004 is free despite there being additional functionality implemented which is normally prevented by the OS licensing restrictions.
If any of you are coming this Sunday (28th March) I will have it up and running for a demo.
Full Changelist
Changes from MM OS Edition 4.0.1 to 4.2.1
Added: Automatic Route/Track 3D Fly-through - Fly along a route or track in 3D View™
Added: Manual 3D Fly-through - Create your own custom flight path in 3D View™
Added: 3D Settings in Mode menu for enhanced resolution and 3D card optimisation
Added: Properties in 3D View for changing background colour and Auto-Play timings
Added: Relief shading print options for highlighting 3D terrain on printed maps
Added: Powerful new Overlay management and multi-media publishing features
Added: Elevation Profile - added display options, scales and printing
Added: Options for lat/long grid, axis labelling and margins on printed maps
Added: "Storage card on PC" option for Send Map to PDA
Added: Join Tracks tool (right-click on Track)
Added: Track - Reduce points tool (right-click on Track)
Added: GPS track smoothing tool with Remove velocity spike
Added: Display of total distance during freehand Track drawing
Added: Overlay / Icons - option to import custom Mark/Waypoint icons
Added: Improved real-time GPS plotting with range circles around current position
Added: Waypoint arrival alarm (right-click in nav window)
Added: Cross-track error alarm
Added: Printed route card also gives distance from start position
Added: Range circles around marks (without any alarm).
Changed: Proximity and Anchor alarm range circles can be set with user-selected units
Changed: Hotspot link from Mark can be direct to web URL
Changed: Hotspot link now uses relative path
Changed: Sync Windows™ zoom levels can be set independently
Changed: Print window and Print to scale are now options in the Print dialogue
Changed: 3D View - stops spinning when another window is activated
Changed: 3D View - remembers last used view settings and window placement
Changed: Route time estimate allows negative value for descent coefficient
Changed: Route-to-track and track-to-route now hides the converted object
Changed: 3D View uses temp folder instead of C:\
Fixed: Text overlay could be edited when locked
Fixed: Tracklog elevation profile, last point was at 0 elevation
Fixed: QCT maps bigger than 2GB displayed negative size in Map list
Fixed: Error when importing overlays with duplicate names
Fixed: "Send Visible Portion to PDA" caused error when used during map refresh
Fixed: Occasional screen flicker when freehand drawing routes/tracks
Discoverer license changes:
Discoverer license now includes real-time GPS plotting and does not allow the import of third-party format maps or map merging and calibration
New Professional license upgrade features:
Enhanced CSV and ESRI Shapefile import
Automatic tracklog segment joining in ESRI Shapefile import
Night colours mode on Pocket PC
NMEA file import (RMC and WPL sentences)
Changes from 3.1.6 to 4.0.1
Memory-Map is now produced in two versions:
MM OS Edition 2004 - to support new Ordnance Survey licence conditions
MM 2004 - standard European and world-wide product
Added: 3D View™ - display any kind of map, chart or aerial photo[/quote]
BBB
PostPosted: Fri Mar 26, 2004 2:13 pm    Post subject: Reply with quote
Gnash - gnash; Wail - wail.
When will I learn?
As soon as I separate myself from some of my earthling money - everything changes. Mr. Green
BBB
BBB
PostPosted: Fri Mar 26, 2004 2:42 pm    Post subject: Reply with quote
This is the way to go - free revision changes I mean.
Maps do change quite frequently and I think suppliers need to show a commitment to their clients and users.
Well done MM - somehow I feel this site may have been influential in MM strategy = well done pocketgps.
If, in the full picture of things, MM realise the marvellous contributions from one BBB they may wish to forward said BBB a copy of their marvellous product I am sure that the aforementioned BBB would be only too happy to receive it :-)
not-BBB
PostPosted: Fri Mar 26, 2004 3:32 pm    Post subject: Reply with quote
BBB,
It is not the maps that have changed, just the application.
I wont get into the restrictions that the OS place on software developers suffice to say that in theory you cannot add functionality to an existing program without charging for the maps again.
Privateer
PostPosted: Fri Mar 26, 2004 3:42 pm    Post subject: Reply with quote
I'm sorry, but it's got to be asked...
... which planet are you from? Confused
Welcome
Welcome to Earth, third rock from the sun. Twisted Evil Mr. Green Thumbs Up
Robert.
Garmin Camper 770 LMT-D
DABurleigh
PostPosted: Fri Mar 26, 2004 9:15 pm    Post subject: Reply with quote
Here is one very confused man, despite a phonecall to Memory-Map about it.
I have a 2003 version of Navigator, and a more recent 2004 OS edition, with OS mapping for Regions 1-6, 3D, etc.
I, too, received an email today, citing:
"Memory-Map is pleased to announce a free upgrade for existing Memory-Map 2004 OS Edition users!".
However, I was confused when following the instructions to load the program, it told me my version was 4.0.1, and the latest release was 4.2.1, click to download here etc.
http://www.memory-map.com/download_mmnav.htm
then told me that this version was NOT compatible with OS mapping, with the further explanation that:
http://www.memory-map.com/memory-map_2004_ordnance_survey_maps.htm
"For the OS edition, free bug-fix releases will be available, but these will not include any new features. The OS requires us to pay additional royalties on the maps if we add new features to our software. "
So I phoned MM, only to be told not to worry, my 2004 OS version WILL indeed be updated. Duly comforted, I downloaded and installed it, to find that all I have is an updated version to Navigator which will NOT load my OS mapping from the 2004 edition. So I'm stuffed, and conclude that MM's claim of offering a free upgrade to 2004 OS, and your reporting of it, is false.
I would be VERY pleased if someone told me I was an idiot and where I was going wrong .....
I will be coming to the pub on Sunday and will tell MM what I think of them in person :-)
DABurleigh
PostPosted: Fri Mar 26, 2004 9:42 pm    Post subject: Reply with quote
OK, I've managed to answer my own question/ frustration.
The answer is to ignore MM's instructions to:
"How to upgrade? - Make sure you have your Internet connection open and then use the Web > Check for updates menu command in Memory-Map to update your software."
and instead simply go to:
http://www.memory-map.co.uk/dl_mm_navigator.htm
which I came across by aimlessly wandering around their website.
Hope this helps someone avoid what I've just wasted a lot of time on.
Clarkey
PostPosted: Fri Mar 26, 2004 11:43 pm    Post subject: Reply with quote
Thanks DA, you probably saved me a load of hassle.
Having only just bought the software I'm very pleased to get this upgrade FOC. Lots of little changes that make life easier so I would have been miffed to have missed out. Then there are the 3D fly throughs, not sure how much use it really is but I love it.
Adrian
PostPosted: Sat Mar 27, 2004 12:32 am    Post subject: Reply with quote
Yep, this happened to me last night when I tried the upgrade.
I was busy all day today so I didnt have a chance to sort it out. I just thought I had meade a mistake somewhere. I uninstalled "Navigator" and then when through the update process again and it worked fine.
I assume that the had the link to the International version, but managed to change it to the correct one before I tried the second time.
Good news is that I didnt need to re-register, and all now works well.
I have got everything ready to demo on sunday if anyone is interested. Hopefully I can capture some tracks as well.
BBB
PostPosted: Sat Mar 27, 2004 2:58 pm    Post subject: Reply with quote
Hi Privateer - is is even worse that that! Or perhaps I should say:
Hello eathlings this is BBB. Message especially for earthling with the handle of Privateer.
Yes I am familiar with this mysterious land of green.
One is still recovering from being transported to what can only be described as a parallel universe. It was (is?) a world in which the A1 is or was the E13 until it became the E17 (if that was just north of the place that used to be called Sheffield it would make poetic sense). A place where the M62 no longer exists but the E20 follows its path almost centimetre by centimetre.
I will not explain - this is far stronger than jetlag - paralleling I mean
8O
PostPosted: Sat Mar 27, 2004 4:31 pm    Post subject: Reply with quote
Come on Guys lets get real.
Everyone knows that E17 is Walthamstow!
BBB
PostPosted: Sat Mar 27, 2004 9:31 pm    Post subject: Reply with quote
Hope y'all have a right good time tomorrow
No harm meant to anyone and none taken
Laughing
chris_de_wet
PostPosted: Mon Mar 29, 2004 4:58 pm    Post subject: Reply with quote
I used the web update function from within MM 2004 and the resultant download applied faultlessly.
Now at last I have been able to sort out all my 'props' into an ordered arrangement.
This to me is the best news in what is a most welcome free upgrade.
Thanks, MM!
Nomad
PostPosted: Fri Apr 02, 2004 6:42 pm    Post subject: Reply with quote
Talk about frustrating trying to upgrade......I was totally confused and tearing my hiar out until the penny dropped. There are in fact two Memory Map sites www.memory-map.co.uk and www.memory-map.com
Trouble is if you are not keeping an eye on your address bar you don't realise you are being switched between the two. You get different downloads from the different sites. One only gives you 4.0.1
the other the latest upgrade which CANNOT be used with 2004 OS maps.
So I wasted hours trying to upgrade, eventually realising I was wasting my time cos I only use MM on OS 1:50K maps.
Nomad
DABurleigh
PostPosted: Fri Apr 02, 2004 9:39 pm    Post subject: Reply with quote
Nomad,
After doing the same myself (see earlier in thread) I thought I'd be helpful and explain my difficulties to MM, so they could be aware when others had similar difficulty. Rather than apologising for their upgrade instructions being duff, as I had been clear to explain, apparently it was my fault for getting onto the .com website instead of .co.uk.
While I'm posting I'll add some questions I had for their technical support which is drastically inhibiting my use of MM since the upgrade. Unfortunately I have had no reply after 3 days
1) The overlay files are not backwards compatible, preventing sharing of overlays (even just a single route, hardly cutting edge option stuff) with family and friends with older versions. One receives an "Unknown object" error. This is a major problem for me; any way around it?
2) I bought the Professional licence so I could add overlay files containing many, many marks/ waypoints. For example, speed camera database, geocache locations, camping sites, etc. Unfortunately obviously the online help documentation has not kept up with the software and the CSV format description is out of date. Merely reading in a CSV file with marks/waypoints having a positive radius (for a proximity alarm) no longer delivers a proximity alarm! The speed camera positions instead have "Hide circle" and no alarm. Just as well I haven't yet accrued points on my licence since upgrading ..... :-(
Just what is the CSV format I now have to use in v4.2.1?
3) Unfortunately I cannot be more specific at this early stage, but after manipulating overlay files the latest MM version crashes, whereas the earlier versions were very robust.
Has this updated version been rushed out for the Outdoor Show?
Page 1 of 3
