Pocket GPS World :: View topic - Navman 510
Navman 510
italian_welsh
PostPosted: Tue Jul 31, 2007 9:59 am    Post subject: Navman 510 Reply with quote
Hi all,I am new to this and would like some help with submitting new speed cameras.I have tried but failed a few times. I get problems with the coordinates .the coordinates off my Navman do not correspond with the ones requested on the submission map page?
Any help would be appreciated,Thanks
Tim Buxton
PostPosted: Tue Jul 31, 2007 10:15 am    Post subject: Reply with quote
What coordinates show on your Navman? We use decimal degrees. It's possible that your Navman is set to use degrees, minutes and seconds but you should be able to change this somewhere in the unit's GPS settings.
Tim
italian_welsh
PostPosted: Thu Aug 02, 2007 9:46 am    Post subject: navman coordinates Reply with quote
Hi Tim,I have checked and changed the settings on my Navman to decimal degrees and to check if it worked I have used the coordinates given on it for an address and when I input these on the grid map it did not show the location I was at but somewhere in amsterdam.
I would really like to know how I can do this for future reference.
Thanks,Enrico
Tim Buxton
PostPosted: Thu Aug 02, 2007 9:59 am    Post subject: Reply with quote
What are the coordinates and where are they meant to be?
Tim
italian_welsh
PostPosted: Fri Aug 03, 2007 9:46 am    Post subject: Coordinates Reply with quote
I have worked out how to do it now.
A big thank you for your help. :D
Enrico
Tim Buxton
PostPosted: Fri Aug 03, 2007 10:26 am    Post subject: Re: Coordinates Reply with quote
Enrico
And will you enlighten us so that others may benefit from your newfound wisdom? Question
Tim
italian_welsh
PostPosted: Sat Aug 04, 2007 5:41 pm    Post subject: Re: Coordinates Reply with quote
Yes of course Smile ,I did not find it easy to understand how to input coordinates for new locations on the website.With your help I did experiment with coordinates(all the digits and letters from the 2 lines on the satnav) for my home address and then checking on the google map to pin point exact location ,so I will try to submit new safety cameras as soon as I find one Very Happy .
22.105 (30 Oct 24)
