Pocket GPS World :: View topic - HP Announce 221x ROM Update
Goto page 1, 2, 3  Next
PostPosted: Sun Mar 21, 2004 10:39 pm    Post subject: HP Announce 221x ROM Update Reply with quote
HP have released a SoftPaq ROM Update for the h22xx series iPAQ's. This update replaces the existing ROM image with an updated version containing all previous updates and roll-ups summarised below. As always, the update will erase all user data and programs on your PocketPC so ensure you read and understand the Readme file before you begin!
Fixes
Corrects the Sleep Mode SD power drain.
Updates the Bluetooth driver to resolve Bluetooth lockup issue.
Corrects iPAQ Backup shutdown after 10 seconds when a backup is scheduled.
All fixes contained in Microsoft Adaptation Kit IIa.
Enhancements
Adds Microsoft Adaptation Kit IIa.
Adds Self-test.
Adds support for the Extended Battery.
Adds support for "Wake on Ring" (NOTE: this requires 3rd party software to function)
Download it here.
Bluecan
PostPosted: Sun Mar 21, 2004 11:52 pm    Post subject: Reply with quote
Dear Darren
You say it will remove data and programs. Is it likely to change any part of the activation of TTN2 when you reinstall it?
TIA
Alan
PostPosted: Mon Mar 22, 2004 12:01 am    Post subject: Reply with quote
No, that should not be an issue.
matt_e
PostPosted: Mon Mar 22, 2004 12:32 am    Post subject: Reply with quote
Just reinstalled TTN2 after a ROM update and no problems.
What is the Microsoft Adaptation Kit??? I can't find any info.
Matt
dmr54
PostPosted: Mon Mar 22, 2004 3:39 pm    Post subject: Reply with quote
Hey,
I believe you mentioned that it fixed the SD Card autorun bug, could you expand a little on this for me as I am not sure as to what you mean.
I ask as I am having problems since upgrading, every time I reset there is now a timedelay until my SD Card is read this means that a folder called SD Card is created I presume due to my reg hack to move the temp internet files to this card. Also my icons are therefore gone fo rprograms I have installed.
I apreciate this is not teh right site for this sort of stuff but I noted your comments on the MS Newsgroup, so hope you don't mind I came here to post a reply Smile
Nice site btw I have just been given a second hand gps so will be taking a long look round Smile
Best regards - Dave
PostPosted: Mon Mar 22, 2004 3:43 pm    Post subject: Reply with quote
It wasn't me who mentioned the autorun bug but another poster replying to my message.
Are you saying that you have these issues after installing the ROM upgrade?
PostPosted: Mon Mar 22, 2004 3:50 pm    Post subject: Reply with quote
The nearest I can ascertain is it's some kind of SDK for OEM PocketPC Manufacturers.
jasb
PostPosted: Mon Mar 22, 2004 5:23 pm    Post subject: new o/s Reply with quote
Hello
since I loaded this new update, everytime I exit a program that uses my bluetooth gps, my connection is dropped in "blue tooth manager" I have to recconect to my gps(fortuna clip-on)
Im using tomtom 2 (nmea 0183v2 bluetooth/com eight),before I was using nmea 38400...but that just freezes it now
and
Copilot 4 live(4800/com eight) this is what it autodetects
I tried updating tomtoms bluetooth driver from 2.06 to 2.07 but this freezes my ipaq?????
Didnt have this problem before. Am I using the right settings??
PostPosted: Mon Mar 22, 2004 6:21 pm    Post subject: Reply with quote
I'm sure it's normal for the BT Connection to be dropped when you exit the application that was using the BT Serial Port?
As for settings, NMEA@4800 is probably the default.
PostPosted: Mon Mar 22, 2004 8:01 pm    Post subject: Reply with quote
OK I plucked up the courage and installed the update this evening!
The good news is that the MSN Messenger, MS Reader and BT updates are all now rolled up in this ROM update. If you had previously installed any of these as individual updates they would have consumed precious memory rather than being held in ROM. Running this update will put them into ROM and free the memory they occupied Smile
No problem issues observed so far. It may be my imagination but the default Today theme seems to have changed as well?
jasb
PostPosted: Tue Mar 23, 2004 5:29 am    Post subject: Reply with quote
Does anyone know if this update solved the following???? Or do we still need to load the fix from www.scarybearsoftware.com
"The Pocket PC 2003 OS appears to have a bug that can slow down the performance of a Pocket PC device, and can potentially cause ActiveSync delays. It has been identified that after every soft-reset of your device, a few extra "Notification Events" are added to the Notification Event Database on your system (This database holds system notifications such as alarms, timed events, etc.). After several soft-resets, a device can have several hundreds of extra notification events that can reduce the performance of a device."
jasb Thumbs Up
PostPosted: Tue Mar 23, 2004 8:26 am    Post subject: Reply with quote
I personally never experienced this issue so didn't bother applying the fix. However I will check the notifications database later today and let you know if its full!
icsys
PostPosted: Tue Mar 23, 2004 8:08 pm    Post subject: Reply with quote
No, my 2210 keeps the connection open which is good if I am switching between applications, i.e from smartST to Anquet. I assumed this was normal?
I experience occasional bluetooth lockup so this update may cure it, but is there a way back once the update has been applied?
PostPosted: Tue Mar 23, 2004 8:39 pm    Post subject: Reply with quote
I'm afraid it's a one way upgrade, no possibility of downgrading afterwards. Having said that I'm happy with it, no issues at all post upgrade.
carl_w
PostPosted: Tue Mar 23, 2004 9:41 pm    Post subject: Reply with quote
Can I do a backup to the CF card, apply the ROM update, then restore from the backup? Don't really want to have to reinstall all the apps...
Page 1 of 3
