bonehead2412 Occasional Visitor
Posted: Thu Jun 07, 2007 5:38 pm Post subject: |
jonah24 wrote: | how do I change autorun program using active sync have tried everything please help gps-boj wrote: | Got TT5 working Ok
set GPS up as
Other Cable NMEA GPS
GPS baud Rate 9600
Serial Cable on SP2:
also you can have both atobe and tomtom on the same card, but need to change the autorun program on the flash_storage (via active sync) to:-
navigation = \MMC_Storage\TomTom Navigator\TomTom Navigator.exe
to use aytobe change back to
navigation = \MMC_Storage\MobileNavigator\MobileNavigator.exe.
Just need to know now how to change the autorun program to choose between the two - anyone any clues?? |
hello i just found that out abut 2 hours ago like with navigation = \mmc and so on
try
player = \MMC_Storage\TomTom Navigator\TomTom Navigator.exe
any problems |
Sallet Occasional Visitor
Posted: Thu Jun 07, 2007 7:41 pm Post subject: |
Managed to install my copy of Mapfactor Navigator 6 on my AytoBe! It is designed to be able to run on WinCE 4.2 as well as Pocket PC 2003 and Windows Mobile 5! Seems quite a detailed package with some interesting POIs. It also seems to run quite quickly although I am yet to compare it to TomTom 6,02 on the AytoBe.
Mapfactor are now selling their version 7 which I haven't bought yet so you might have difficulty getting it. There are still some sites advertising it for sale though |
RICHCON Occasional Visitor
Posted: Thu Jun 07, 2007 10:03 pm Post subject: |
id10t wrote: | phonic wrote: | How about using the AyToBe as a GPS receiver on your LapTop?
The software you need is all Freeware and listed below:
1) GPS2Blue 1.7
http://users.skynet.be/hofinger/GPS2Blue.html
2) .NET Compact Framework 2.0 Service Pack 2
http://www.microsoft.com/downloads/details.aspx?FamilyID=AEA55F2F-07B5-4A8C-8A44-B4E1B196D5C0&displaylang=en
4) Microsoft ActiveSync 4.5 (only tested on this version)
5) HW VSP
http://www.hw-group.com/products/hw_vsp/index_en.html#download
Install Active Sync on Laptop (if not already using it)
Install .NET 2.0, but does not start via ActiveSync, you need to copy the .cab over and install that way.
Install Gps2Blue on AyToBe.
Settings: IP should be 192.168.55.101, remote: 192.168.55.100.
tick TCP/IP. GPS is on COM6 at 9600. Click "On" to start.
Install HW VPS on Laptop. Settings: Select(settings tab): HW VP work as the TCP Server only.
Unselected(settings tab): Don't create VSP Port if Ping to
remote device failed.
in VSP tab: IP: 192.168.55.101(your IP) Port: 31873
Port name: COM5 or any free port name. Server Port: 31873.
Theses settings work both on my Laptop and Desktop pc, running Windows XP SP2.
Make sure you always install software to MMC_Storage. Good idea to make a folder called Program Files. |
cool, I got netstumbler (on my laptop) working with this setup. |
hi there .. I need help.. was trying to install .NET 2.0 to my A2B but still no luck ,, dunno what i am doing really ..will someone guide me pleaseee,, really appreciate it ..thanks 8) |
Psychobiker Occasional Visitor
Posted: Sat Jun 09, 2007 2:58 am Post subject: |
No matter what I do, I CANNOT get the CAB to install!
I've connected by activesync, navigated to the directory in which the tomtom6 and tomtomtoday cab files are stored, but where do I go from here? All it does if I click on the CAB file is give me the properties!
And if I try by card reader...not a valid win32 application
L |
Posted: Sat Jun 09, 2007 3:22 am Post subject: |
No luck with the WinCE conversion either - whenever I try to copy the autorun file to the desktop, it's telling me access is denied! WTF is this, is it read only or what?! |
Posted: Sat Jun 09, 2007 8:36 am Post subject: |
Psychobiker wrote: | Hi,
L |
You have to copy the cab file onto the device by Activesync and run it from there. Just copy it into My Documents on the Aytobe and double click on it from My computer. |
Posted: Thu Jun 14, 2007 1:03 am Post subject: |
Hello! Does anyone know of a backup/restore program that can run on this machine? I have had to do a reset on the road a couple of times when it's locked up and I have been unable to restart TomTom and had to do a restore at home using Activesync, not much use if you get stuck in the middle of nowhere! I know someone was asking earlier if one can restore from the SD card but I haven't seen a reply. Is everyone getting bored with this machine? |
Mike1963 Occasional Visitor
Posted: Thu Jun 14, 2007 9:04 am Post subject: |
Not getting bored with mine - I use it constantly!
For backing up I keep a folder on my PC with everything from the A2B. To restore I just copy it over. I suppose you could do the same with an SD card.
Has anyone tried the PocketPC version of Route 66 Navigator? I have the full version on my laptop and found it very good. |
profquatermass Occasional Visitor
Posted: Thu Jun 14, 2007 1:27 pm Post subject: AY2BE Keyboard query |
Anyone know if a USB Keyboard can be used with the USB socket on the AY2BE GPS device?
I need to be able to type!
DaiC1 Occasional Visitor
Posted: Sat Jun 16, 2007 10:46 am Post subject: |
Sallet wrote: | Hello! Does anyone know of a backup/restore program that can run on this machine? I have had to do a reset on the road a couple of times when it's locked up and I have been unable to restart TomTom and had to do a restore at home using Activesync, not much use if you get stuck in the middle of nowhere! I know someone was asking earlier if one can restore from the SD card but I haven't seen a reply. Is everyone getting bored with this machine? |
Yea me to a backup/restore on th fly would be ideal for me. I installed tt6.02 and got it to run using the regedit and reg file posted on Datacave.
I droped the regeditor and the reg file in the TT directory, now I can do a reset and run Regedit import the ref file and alls well on the road.
https://datacave.co.uk/showthread.php?t=156339
https://datacave.co.uk/showthread.php?t=155209
Then do a full restore when I get home.
Hope this helps. |
Posted: Sat Jun 16, 2007 10:50 am Post subject: |
Just have 2 problems I can't resolve.
1.After installing gps sentry the menu button dos'nt work so I cant config the com port.
2. The top part of the Gps sentry is not shown in the display so I cant close the program.
Any ideas. |
happyhkv Occasional Visitor
Joined: Aug 18, 2006 Posts: 34 Location: West Midlands
Posted: Mon Jun 18, 2007 7:46 am Post subject: |
DaiC1 wrote: | Just have 2 problems I can't resolve.
Any ideas. |
Hi DaiC1, which version of GPS sentry have you installed? |
burberry316 Occasional Visitor
Posted: Mon Jun 18, 2007 1:58 pm Post subject: |
hi guys
bought a aytobe sat nav and implemented nearly all the tricks and hacks i have read on here
but i cannot get tom tom 6 to find the maps
it runs but the says no maps installed
any help would be greatly appriciated
many thanks |
Posted: Mon Jun 18, 2007 7:50 pm Post subject: |
happyhkv wrote: | DaiC1 wrote: | Just have 2 problems I can't resolve.
Any ideas. |
1.5 some one said to use 1.3 but I can find it. |
Posted: Mon Jun 18, 2007 7:57 pm Post subject: |
burberry316 wrote: | hi guys
many thanks |
You have the same problem that I had I posted a link to another site above {about 4 post up}
You need to run the reg editor then inport the reg update file.
that should solve your problem.
Its some thing to do with mydocumnets folder in WinCe |
