samjohnson Occasional Visitor
Posted: Wed Jun 13, 2007 12:16 pm Post subject: |
We'll need to see how it all works in practice, but I'm not sure it would be that easy to abuse the system. I'm sure this is something they've thought of, and in any case they have their levels of trustworthiness, the lowest of which is reported by 'some', so it looks like they will be filtering the corrections and that more than one person would need to submit the same correction before it is redistributed. It sounds great, but we need to see it in action before we know for sure. |
uocooper Regular Visitor
Joined: Nov 15, 2005 Posts: 63 Location: Portland, Oregon
Posted: Wed Jun 13, 2007 3:32 pm Post subject: |
Robin2 wrote: | If the authorship of corrections is made clear, I would be prepared to accept corrections from people I trust (ie people on this forum whom I feel I know after reading their contributions over the years).
Robin |
I was thinking about this as well. The fact is that there are lots of users that will be the only person to report an error but that doesn't mean it's not something that won't affect many other GPS users or that it's not an important fix. It all comes down to establishing trust levels. To a certain extent, things like blocked roads can probably be verified by other users using available satellite imagery where available. The most important thing is that this doesn't end up causing multiple people to report bad data thereby becoming part of a higher tier of trust.
As a community, we could certainly help push updates along but the trick is how to be absolutely sure they are corrections that actually need to be made.
Even though the Map Share corrections will be provided to Teleatlas it would still probably be best to use both Map Share and Mapinsight since Teleatlas does give more priority to corrections depending on the number of reports they get. _________________ Creator of the Bright & Vivid scheme available through HOME.
Report map errors- http://mapinsight.teleatlas.com |
PaulBt Lifetime Member
Joined: Sep 22, 2006 Posts: 188 Location: Kempsford, UK
Posted: Wed Jun 13, 2007 9:38 pm Post subject: |
At last with MapShare I can put back in some of the deadends that I was able to mark as "avoid areas" in version 3. At least I will get the benfit of my corrections, and if I can share those with others then that is good.
I had been thinking about saying to TT about changing the voice commands (I know it can be done using conversions), as some people I know get confused between left and right and use "there side" or "the other side" !!!
I hope that the voice stuff works, as no-one can hear me on the hands-free at present. _________________ TT720 V8.010, regular audio book user.
WestEuro v805 connected to E90 on O2
TT910 V6.525, TTN5, TTN3, TT on Psion 5mx |
DennisN Tired Old Man
Posted: Wed Jun 13, 2007 9:48 pm Post subject: |
PaulBt wrote: | I hope that the voice stuff works, as no-one can hear me on the hands-free at present. | Are you not using the external microphone which came with it? - Sorry, treat this as rhetorical, it's up to you to choose for yourself.
My wishlist for the new range (or the new software) is for the "Warn ONLY When on Route" to be sorted out. It's so annoying to get warnings for stuff off route. _________________ Dennis
Two of them are obesiting!! |
kalvin928s4 Occasional Visitor
Posted: Thu Jun 14, 2007 9:44 pm Post subject: mmm 910 or 720? |
im more than happy with my present set up especially as i have full handsfree with my ericsson p990 inc writing and hearing sms messages over my speaker but as usual I like to keep upto date.... the thing thats putting me off is the 'loss' of the 20gb hardrive which ive fully backed my mp3's onto.
Im in London everyday and im sure some of the new features on the new units will be more than helpful..... but do you think a 920 will come out with bigger harddrive? and that would most definately sway it for me
thx |
Darren Frequent Visitor
Posted: Thu Jun 14, 2007 9:59 pm Post subject: |
I wouldn't worry, a 910 upgraded to v7 will serve you fine once the upgrade becomes available. _________________ Darren Griffin |
tazzz78 Occasional Visitor
Posted: Thu Jun 14, 2007 10:30 pm Post subject: Active mount |
Would it have an active mount? Cause it looks like mount for TomTom One, which obviously is not an ctive one. Anyone knows? Thanks |
Posted: Fri Jun 15, 2007 7:30 am Post subject: |
It does not have an active mount. _________________ Darren Griffin |
Posted: Fri Jun 15, 2007 12:58 pm Post subject: |
The custom cursor feature is nice, Garmin had a choice and there were some custom cursors produced for their branded Nuvi's i.e. those supplied through Mini dealers had a Mini Cursor complete with chequered roof.
Now not only do you have a pre-installed selection to choose from, you can also make your own, it's a 24-Bit 80x80 pixel bitmap. Here's one I knocked up of My Land Rover (the red is seen as transparent on the device).
Posted: Fri Jun 15, 2007 2:37 pm Post subject: |
Darren, what is the RGB code for the red you have used as this might be handy for transparent POI icons, or worse still might affect the speed camera icons - Mike |
Posted: Fri Jun 15, 2007 2:46 pm Post subject: |
The RGB Code is 255,0,0 _________________ Darren Griffin |
DaveMatthews Regular Visitor
Posted: Sat Jun 16, 2007 11:31 am Post subject: |
Hi all,
I've almost given up on waiting for Navigon to get their MobileNavigator range fixed and these new TT solutions look very promising. There are a lot of features I'm not bothered about but TMC is very imoprtant for me. Does anybody know whether these new units will handle TMC properly in the UK and will allow an external aerial (ie a "splitter" from the car radio antenna) to be plugged in?
Cheers,
Dave |
wobbly_rider Occasional Visitor
Posted: Mon Jun 18, 2007 1:11 pm Post subject: no active mounts.. |
Further to the post above - if there's no active mount, does anyone know if the X20's have an "audio out" jack?
I ask as the Rider2 doesn't (apparently) so it won't connect to my bike's intercom system!
thanks |
Posted: Mon Jun 18, 2007 1:37 pm Post subject: |
yep they have an audio output jack |
Posted: Mon Jun 18, 2007 1:47 pm Post subject: Re: no active mounts.. |
wobbly_rider wrote: | Further to the post above - if there's no active mount, does anyone know if the X20's have an "audio out" jack?
thanks |
It would if your intercom has a BT Interface? _________________ Darren Griffin |
