nickgill Occasional Visitor
Posted: Sat May 12, 2007 12:33 pm Post subject: Tom Tom X10 menu structure |
I have a TT510 v6.525 and I'm trying to alter the menu structure of ie swap the Change Prefs on page 1of 3 with Clear route on page 1 of 4 etc, Ive looked up the topic etc in this forum and found some damn good info but it all seems to be for the earlier versions of TT x00any one out there tried to do the same thing
I realise that some of the info nn Open tomtom is there but as I said it seems to be for the early versions of TT x00 not for TT x10
ive done what is suggested in the forums and on Open Tomtom but its still a problem ??
any advice please
regards
nick _________________ RISC OS does it better and faster using Strong ARM |
Oldboy Pocket GPS Moderator
Posted: Sat May 12, 2007 3:06 pm Post subject: |
The menu structuring is the same throughout the TT range. It works all the way from the Classic to the x10 series.
You need a Folder with the name SdkRegistry and a File called TomTom.mnu
All you need to do then is to work out which Menu Items you want. You can have a bare minimum, up the the Maximum, and all points in between.
If you haven't got a .mnu file then you will need to create one.
So, at what point does it become a problem? _________________ Richard
Posted: Sat May 12, 2007 3:10 pm Post subject: |
so sorry problem cured, all menus sorted
xxx _________________ RISC OS does it better and faster using Strong ARM |
TomDavison Lifetime Member
Joined: Mar 02, 2006 Posts: 384 Location: Bedford, England
Posted: Sat May 12, 2007 3:59 pm Post subject: |
I've just had a look at my backups on the PC. Neither of them (700 and One V2) contains such a folder and neither have a file .mnu . Does this mean I don't have a full backup? |
Posted: Sat May 12, 2007 4:45 pm Post subject: |
Don't worry your back-up is fine, you will only have the files/ folders mentioned above IF you have created a custom menu for the device.
Typically this is when you install a third party application such as POICapture - Mike |
sweepdog Occasional Visitor
andydigital44 Regular Visitor
entwood Regular Visitor
Posted: Sun May 13, 2007 11:25 am Post subject: |
I must agree with andydigital44 ....
The tomtom menu designer from that site is simple to use and extremely effective .. I wouldn't be without it.
Regards
Entwood |
Posted: Sun May 13, 2007 12:01 pm Post subject: |
I did find that website being mentioned before, but it was just the domain name which gave a forbidden error
Thanks a lot |
123dixie123 Occasional Visitor
Posted: Sun May 13, 2007 2:30 pm Post subject: |
Ok folks I can do all this using gregorys kit but I had allready installed the brilliant Mobilnova media centre which I use daily. The prob is how do I get the 'media' of the installed app button onto gregs system to then be able to move it onto my front screen? I cant live with out my videos... :D |
Posted: Sun May 13, 2007 3:16 pm Post subject: |
Drag the icon that says "User SDK App" on it to the position that you want it in your menu structure, as you do this you will get a pop up box asking you which add on program you want it to point to. If Mobilnova is the only add-on SDK program you have installed, then select SDK 1, if you have the camera capture software installed from this site as well then it may be SDK 1 or SDK 2 for example. Just keep trying by changing the number until you get the correct program icon showing up on your tomtom when you import the .mnu.
The above information is in the FAQ that is installed to the PC, have a look under "START" , "Programs" , "TomTom Menu Builder Manual". |
Posted: Mon May 14, 2007 8:14 am Post subject: |
Ok. Ta V much. I just knew there would be somebody who knew how to do it |
