psionman Regular Visitor
Joined: Dec 23, 2003 Posts: 62 Location: Nottingham (UK)
Posted: Thu Feb 26, 2004 4:46 pm Post subject: Basic Functionality |
I live the UK and use Holux/TT2 for street navigation
I'm now interested in getting some topo s/w an would be pleased to get some advice on Memory-Map
I would use it for running, and things like total distance, average speed, distance climbed etc would be nice to have features. Can Memory-map help with this? |
lbendlin Pocket GPS Staff
Posted: Thu Feb 26, 2004 5:50 pm Post subject: |
No. It's a topographical software, not a lap timer.
Try getting some other program for that - i believe there are some around that are specializing on logging rather than "orientating" _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2143 Location: Surrounded by A1, M1 & M25
Posted: Sun Feb 29, 2004 5:49 pm Post subject: Memory Map |
Memory Map offers a track record function which you can set by minimum time update interval and minimum distance update interval. If you go back to this track later it will show your speed during each interval and your average and maximum speed as well as your altitude. It will also show the total time and distance from the start for each point. You can look at the altitude profile for the track you recorded.
As this track data can be exported you could later analyse it using an alternative method |
Posted: Tue Mar 09, 2004 1:50 pm Post subject: |
Thanks MrT
Most helpful! :D |
Darren Frequent Visitor
Posted: Tue Mar 09, 2004 2:50 pm Post subject: |
if you purchased a datalogging GPS such as Royalteks Bluetooth unit you coudl carry just this whilst running and then download ther log on your return for analysis using Memory-Map on your PC. It's also a simple process to archive each session's log file and these can be replayed through any current or forthcoming app that uses GPS data _________________ Darren Griffin |
MikeB Frequent Visitor
Joined: 20/08/2002 11:51:57 Posts: 3859 Location: Essex, UK
Posted: Wed Mar 10, 2004 2:41 am Post subject: |
You could also achieve the same effect by buying a cheap Garmin Etrex or Geko 201 , and then downloading your tracklog to Memory-Map.
The advantage of the DataLogger is that you can play back the track to most gps enabled applications.
The advantage of the handheld GPS is that you can use it as intended ie a GPS. _________________ Mike Barrett |
