Pocket GPS World :: View topic - WM5 running TTN5 on HX4700
JDavid
PostPosted: Sun Mar 18, 2007 6:12 pm    Post subject: WM5 running TTN5 on HX4700 Reply with quote
I have upgraded the OS on my HX4700 to WM5 and installed TTN5 5.100 successfully. However it seems a little slower than Win CE 2003, is there anything I can do to speed it up?
PostPosted: Sun Mar 18, 2007 6:19 pm    Post subject: Reply with quote
Put it back to WM2003SE, the WM2005 loaded to a device that was never designed to run the OS is not a good idea, I have tried WM2005 on my 4700 and it slowed down - turnng a decent device into a real slow coach, probably not what you want to hear - but this is my main advice, the remainder are just a few ideas to help you out.
There have been updates for the WM2005 and some people have experianced a speed up - but if I want to use WM2005 (or 2006) I will get the hardware that supports it from day one.
As you are using TTN5 you should make sue that all the POI installed are disabled (change preferences/ enable_disable POI) - de-select the whole lot and use "Warn When Near POI" instead this is less intensive on the processor - Mike
argosafe
PostPosted: Sun Mar 18, 2007 10:44 pm    Post subject: Reply with quote
I fully agree. My WM2005 XDA is not fast, even when using pocket hackmaster to speed it up. Forget WM2005 unless the device comes shipped as new with it...
XDA Orbit (the best so far)
XDA 2S
IPAQ 5455
IPAQ 4700
Globalsat Bt 338
Globalsat 337 CF reciever
Navman sleeve
256Mb Kingston CF Card
Lexar 512Mb card
Toshiba 1Gb SD card
JDavid
PostPosted: Mon Mar 19, 2007 5:11 pm    Post subject: Reply with quote
I have now updated the rom to 2.01.05 which is later than that supplied with the WM5 upgrade and the speed is discernably better. I think it is still slightly slower than WM2003 but the difference is not annoying me so much.
For the moment I am going to stay with WM5 for two reasons:
a) The non volatile memory
b) Slightly better management utilities
I might try pocket hackmaster, is there a downside to this?
Thanks guys.
PostPosted: Mon Mar 19, 2007 9:02 pm    Post subject: Reply with quote
But the 4700 has memory that doesn't get wiped out in the event of a reset even when running 2003SE, so long as you have a decent back-up program installed (Sprite Back-up is supplied as standard with the device - and is considered the best IMHO) you can hard reset the device and be up and running within 2 or 3 minutes.
Next you will be wanting to load WM6 Crossbow on the unit, although I doubt that will be made available for the 4700, shame though as it really does speed up the XDA-Exec - I appreciate I said earlier not to try new software on devices not designed for the new OS - but in this case it really did/ does improve the unit, the 4700 on the otherhand does not respond to the newer ROM to be of benefit IMHO - Mike
JDavid
PostPosted: Tue Mar 20, 2007 7:09 pm    Post subject: Reply with quote
UPDATE
TTN5.10 is crashing when I "browse map" so it looks like I will have to go back to WM2003 after all.
Why did HP release WM5 for this pda then?
Mullet
PostPosted: Tue Mar 20, 2007 8:29 pm    Post subject: Reply with quote
deleted
