daiashthomas Occasional Visitor
![](modules/Forums/images/avatars/17177565443b9f0f6b9698.gif)
Joined: Dec 18, 2005 Posts: 29 Location: South Wales, UK
Posted: Sun Jan 21, 2007 4:41 pm Post subject: |
this could be achived by fitting the Nokia BL-6C its only 1mm-1.5mm thicker than the BL-5C _________________ Qtek 2020i PDA
SPB Pocket Plus 3.0.4
PocketMusic Player 4.03 (even started to make skins)
Minimo (firefox)
SNES Emulator
TomTom Navigator 5
ThinkNavi Car Cradle GPS Reciever
2Gb 120x SD Card |
footman Regular Visitor
Joined: 05/06/2003 06:48:54 Posts: 150 Location: Camberley, Surrey
Posted: Thu Jan 25, 2007 11:38 pm Post subject: |
absolutely a great piece of kit! Sat alongside my BT338 on my desk it found a fix in half the time with twice as many sats.
The "sleep " function is also useful particularly for using with topo maps like memorymap.
No longer will I have to fiddle with the GPS unit to turn it on as well as turning on the pda. |
evo3rs Occasional Visitor
Posted: Fri Jan 26, 2007 8:27 pm Post subject: Tomtom 6 Baud Rate settings |
Sorry OT
Quick queston, please can someone confirm if 115200 bps baud rate is the correct setting for Tomtom Nav 6. TIA |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Fri Jan 26, 2007 8:46 pm Post subject: |
No. Default is 38400 _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Jan 26, 2007 8:50 pm Post subject: |
lbendlin wrote: | No. Default is 38400 |
Thanks a lot!. I will set it to 38400. |
Posted: Mon Jan 29, 2007 10:16 pm Post subject: |
ordered one from ebay less than 40 quid
i already have the higher capacity nokia battery (BL-6C) so i'll let you know if it fits and if there is much of an improvement
i know this battery make hell of a difference once fitted into the Nokia N-70 which comes shipped with the BL-5C _________________ Qtek 2020i PDA
Minimo (firefox)
SNES Emulator
TomTom Navigator 5
2Gb 120x SD Card |
okk Occasional Visitor
![](modules/Forums/images/avatars/13978496745c8643d41354.gif)
Posted: Tue Feb 06, 2007 12:35 pm Post subject: |
I did have an BT338 and the good thing about this GPS is that it did not jump away every ½ sec. on my tomtom like the TomTom-BT-GPSII do.
Does the BT-Q810 & 818 jump on the tomtom navigation ? |
Posted: Tue Feb 06, 2007 10:26 pm Post subject: |
no jumping _________________ Lutz
laimtoh5 Occasional Visitor
Posted: Thu Jun 21, 2007 10:18 am Post subject: Keeps cutting out on n73 |
I wonder if anyone else here uses the i-Blue 737 with Nokia n73 running tomtom mobile 6 - my setup works perfectly with a BT-77 GPS BT receiver, but the signal (I need to get someone to check if it's GPS or BT, not done that yet as it's very distracting to read small print whilst driving ) cuts out every few minutes with the 737.
I updated the firmware about 2 months ago which fixed this problem on the n73 amongst others, I'd like to avoid having to do another firmware update if possible as the phone's running fine otherwise. |
ms-uk Occasional Visitor
Posted: Tue Jul 10, 2007 9:27 am Post subject: i-Blue 737+ |
I just picked up one of these from Ebay for £35 delivered, and its WAY better in use than my old Fortuna Slim. Note its the + model, so it looks like it will last 32 hrs in constant use (not yet tested) and 320 / 360 hrs standby. Looking at the specs its a higher capacity battery, and a different chipset ("32" channels), and the premium over the std 737 is about £2. I get a fix indoors, in London, in a basement in less than a minute pretty much all the time. In the car its seconds
On a closing note, the auto on off is a dream. I travel a lot, and its so handy having the unit in a small pocket or laptop bag. Fire up Tomtom (or Smart2go) and I am "unlost" pretty quickly. 10/10, really impressed. :D |
Posted: Tue Jul 10, 2007 5:12 pm Post subject: |
BTTT - has anyone else had their signals drop out frequently? I'm scuppered because, stupidly, I bought this fairly expensive item (I don't like to see £40 go down the drain ever) from a Hong Kong based ebay seller, and of course they insist that it be returned by insured post which although is understandable to avoid arguments over who damaged the goods when it arrives, also conveniently avoids any point in returning the item as faulty.
They also suggested a firmware upgrade but I cannot see why as my current GPS receiver works fine, and the bluetooth protocol is the same. More like goofy firmware on the GPS receiver really.
My second question is if they are so good, are there any UK sellers of this product? It's not the product, which everyone bar me seems to be pleased with, just the fact an overseas seller has prevented anyone returning faulty goods economically. I won't be buying anything over £15 delivered from ebayers abroad ever again and I would warn anyone thinking of buying one of these GPS units from Hong Kong (i.e.dgkit ebayer) to think hard before handing over your money; alternatively find a different unit sold in this country and you have a better chance of sorting it out.
Phil. |
Posted: Tue Jul 10, 2007 5:39 pm Post subject: |
OK rather than edit my last post, it explains how I feel about the damn 737 right now , I've found the answer to the n73/737 dropout problem here
Quote: | Per our tests (5 tests) on Treo 650 (with Always On utility installed) and connected to the i-Blue PS-737 or Qstarz 818, both units will randomly get disconnected from the GPS Info program.
It may be connected for 10mins to 2 hrs before the GPS automatically gets disconnected. The manufacturer claimed to have fixed this problem but our recent shipments (in the last 15 days as of today) hasn't show any sign of improvement to this problem.
Hence, avoid i-Blue 737 or Qstarz 818 until we confirm that they have fully patched this problem. |
(this confirms the 737 is similar in its chipset at least, to the 818)
And:
Quote: | Has anyone had any problems with dropout on the Bluetooth connection with the BT-Q818?
My Nokia N73 (updated to the v3 firmware) loses the connection with it every couple of minutes or so, and I've read elsewhere that some other devices have 'issues' with it (e.g. http://discuss.treocentral.com/showthread.php?p=1204066)?
Regards
TTMC |
Quote: | *Qstarz BT-Q818/BT-Q810 is featured with Auto On-Off function (Sleeping mode) for power saving. However Nokia N73/E50 does not support Sleeping mode, so it may interrupt the Bluetooth connection when pairing with Qstarz BT-Q818/BT-Q810 GPS receiver. For Nokia N73/E50 user, please consult Nokia service center for latest firmware update. |
I think I'll forget about this auto sleep malarky, total waste of time for me in fact as I was going to run continuous power from an unswitched, fused cig lighter socket in the boot where it had the power to receive strong signal but out of view. I'll look out for another that doesn't have sleep facility, the n73 is such a good phone I can forgive it this!
Still need a unit with a good signal pickup though, I'll keep reading here and check who's using one with an n73 before falling into the same trap again. In view of these problems, the manufacturer should test their product with every available item on the market at that time and not wait for the customers to do their technical research for them. It's no wonder they don't sell in the shops, can you imagine Dixons staff dealing with n73 owners (quite a few of us) and getting unsaleable seconds back? Think the 737 and Qsartz companies would go bust quickly.
Rant over, now I'm the wiser
Phil |
happyhkv Occasional Visitor
![](modules/Forums/images/avatars/gallery/octa_feathers.jpg)
Joined: Aug 18, 2006 Posts: 34 Location: West Midlands
Posted: Fri Aug 24, 2007 6:31 pm Post subject: |
Anyone here know a compatible bluetooth for N73 without the problems relating to 737. |
hashwood Occasional Visitor
Posted: Thu Jul 17, 2008 2:25 am Post subject: any news? |
Did Nokia fix the problem in current firmware ? I have an E50, is it compatible ? |
