Pocket GPS World :: View topic - Windscreen Mount
Windscreen Mount
zogman
PostPosted: Mon Jan 15, 2007 11:01 am    Post subject: Reply with quote
i can only suggest the obvious tips mate, clean the window and the sucker and use a bit of moisture on the sucker.
Pedro2NR
PostPosted: Tue Jan 16, 2007 6:51 am    Post subject: Reply with quote
Are you locking it to the second lock position?
classy56
PostPosted: Tue Jan 16, 2007 10:40 am    Post subject: Reply with quote
Are you putting it on a *flat* part of your screen?
Tomtom Go730T
App 8.300
Map v815.2003
To old to die young.
TomDavison
PostPosted: Tue Jan 16, 2007 3:59 pm    Post subject: Reply with quote
When you fix the sucker on the screen, and tighten it you are creating a partial vacuum between the screen and the sucker, but there is always some air inside. If that air is cold, it will expand as it warms up, reducing the vacuum, and possibly allowing the mount to fall off. If you're going out on a cold day, it's always worthwhile refixing the mount after the car has warmed up. That way you restore the vacuum to its designed level. It's even worse if the screen is damp, because as well as the air warming, any moisture trapped inside the sucker will also evaporate, increasing the pressure even more. And yes, having the heater on full on the screen will make it even worse.
Privateer
PostPosted: Tue Jan 16, 2007 4:51 pm    Post subject: Reply with quote
I use one of those demister pads (a sponge covered in Chamois) placed under the TomTom ONE, which partially supports the weight of the ONE and starting on a cold day on 100+ mile journeys the ONE hasn’t moved. It’s also a good reminder when you pack the ONE away at the end of the journey to use the demister pad to wipe away the tell-tale circular sucker mark from the windscreen.
I’ve just received the Brodit mount for the TomTom ONE so I’ll fix it up and hopefully be able to write a review in the not too distant future.
Robert.
Garmin Camper 770 LMT-D
zogman
PostPosted: Tue Jan 16, 2007 5:26 pm    Post subject: Reply with quote
if possible its best not to use the windscreen mount.... for various reasons like marks left on the windscreen and the sucker falling off whilst driving...try and buy or adapt the mount to a permanent one , located somewhere on the dash...
zogman
PostPosted: Tue Jan 16, 2007 5:37 pm    Post subject: Reply with quote
further to my last post, here's some pics to show you what i mean......
Privateer
PostPosted: Wed Jan 17, 2007 1:24 pm    Post subject: Reply with quote
I’m not a fan of mounting SatNav equipment on an air vent. I don’t think that they are strong enough.
Have you had a look at the Brodit ProClip for your particular vehicle?
Robert.
PostPosted: Wed Jan 17, 2007 1:59 pm    Post subject: Reply with quote
When I first got the GO710, for several days I was driving myself nuts over the sucker falling off my Renault Kangoo windscreen.
I suddenly discovered that I had it so low that it was partly on the little black dots which form a border to the windscreen. They are little lumps of black stuff (sorry for the tech-speak, but we must be accurate) and they were slowly degrading the vacuum. In my case (Renault also) it was this simple. This could be what classy56 refers to.
