longy Occasional Visitor
Posted: Fri Jan 12, 2007 12:12 am Post subject: TT6 and acer n35 help. |
hi all im running TT6 on a acer n35 its working fine apart for a few probs
first prob when i set my home address and quit the programme then restart it
i have to renter it again ie navigate home.
second prob is poi warn i set it up but it doesnt save it, when i restart tomtom
i have reset it up again.
next, post codes when i enter a post code its realy slow ie tap a letter and it takes about 5-10 seconds to register.
i think thats about it, cheers in advance. ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
Oldboy Pocket GPS Moderator
Posted: Fri Jan 12, 2007 7:43 am Post subject: |
Have a read through THIS. I don't know if it works on the N35.
Also make sure the Memory Card is not set to Read-Only.
I don't know why the Postcode Input should be that slow. _________________ Richard
buster0007 Occasional Visitor
Posted: Sat Jan 13, 2007 2:14 pm Post subject: |
Hi I see you are running tt with the acer n35 I also have a n35 but it cant find the gps I have tried all the settings on all the comm. Ports and still it wont find the gps can you tell me if you have a driver or a utility on your n35 to allow it to work many thanks |
mgibbs Occasional Visitor
Joined: Jun 07, 2004 Posts: 48 Location: North Lincolnshire, UK
Posted: Sun Jan 14, 2007 12:39 pm Post subject: |
buster0007 wrote: | Hi I see you are running tt with the acer n35 I also have a n35 but it cant find the gps I have tried all the settings on all the comm. Ports and still it wont find the gps can you tell me if you have a driver or a utility on your n35 to allow it to work many thanks |
I've installed both TomTom 5 and TomTom 6 on n35s and they have just worked with nothing else needing installing. You should see the port for the built in GPS antenna (sorry I can't remember its description) when you select the GPS.
Mark _________________ iPaq 2210, TomTom 5.21, Holux CF100 gps cradle, Holux GPSlim 236, 512Mb CF card, 1Gb SD card. |
Mystery Regular Visitor
![](modules/Forums/images/avatars/145186102042be746720d66.jpg)
Posted: Sun Jan 14, 2007 1:20 pm Post subject: |
Settings for Acer N35 for both TTN5 and 6 are :
Other NMEA
Baud Rate 57600
GPS on NAVAGATOR (their spelling not mine)
Hope this helps _________________ Mystery
O2 XDA Orbit 2
TTN6.030
Posted: Sun Jan 14, 2007 8:22 pm Post subject: |
Hi thanks for the replies I will try to explain further when I open the Tom-tom program I go to show gps setting and then configure select other cable nmea gps and then I have tried all the different baud rates I then have 5 different comm. Ports
1= SC2410 USB cable
2= COM 3
3= S2410 IrDA 2410
4= S2410 uarto
5= gps on navigator
the one I think should chose is gps on navigator and I have tried all the baud rates on this then on the gps status screen in the top left hand corner it says no gps device and the yellow and blue circle in the top right hand does not turn I have also tried all the different comm. Ports all with the same outcome is it possible I need a driver or utility to get the GPS working or do you think the GPS is broken thanks again |
Posted: Mon Jan 15, 2007 10:00 am Post subject: |
The settings I posted above work on my Acer N35.
When starting the GPS Unit (By flipping up the receiver at the back) does a blue light flash at top left of device?
If not then soft reset and see if the light comes on and flashes. If not I would suggest that for some reason the unit is not connecting. That would be the reason that TTN reports no GPS device.
Try a hard reset. Re-install TTN and see if that cures it. If not then I would suggest that the unit has become faulty.
There are no additional drivers required to operate the GPS unit on the Acer N35 as it is all self contained.
O2 XDA Orbit 2
TTN6.030
Posted: Mon Jan 15, 2007 11:03 am Post subject: |
Hi thanks again for the reply yes the blue light flashes and I have tried a soft and hard reset also reinstalled TT but no joy I know some pdas have a gps icon in windows and you can adjust settings there but it looks like this gps is faulty thanks again |
Posted: Sat Jan 20, 2007 12:59 pm Post subject: |
hi update got it workng now i uninstalled it and put tomtom on a new sd card
(a standard speed sd card) everything works smoothly starts up faster and the post code input works as it should.apparently the sd card iwas using was a high speed one,now very happy.all i can think of is that the acer n35 doesnt
like high speed sd cards.
oh just one thing when i put my post code in it comes up with unamed road? |
