stevejewell Occasional Visitor
Posted: Mon Jan 01, 2007 5:36 pm Post subject: low volume on Garmin Nuvi 360T |
I have the new Garmin nuvi 360T the volume seems very low even when set to full . has anybody else found this |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Tue Jan 02, 2007 11:12 am Post subject: |
yep. best option is to turn the stereo down a bit or get some cheapy little battery powered speakers and plug them into the headphone socket.
i put it down to the slim design of the nuvi meaning a smaller speaker was needed to 'fit' inside.
MaFt |
Posted: Tue Jan 02, 2007 2:20 pm Post subject: low volume |
They say sometimes simplest ideas are the best I might just do whatb you think |
Posted: Wed Jan 03, 2007 12:00 pm Post subject: |
or if you use the mp3's on the nuvi then plug in a headphone jack to tape adaptor into our tape deck (assuming you don't have a cd player!). it pauses the music when it gives you wanrings and directions. either that or if you have a cd player then try a (now legal!!!!) fm transmitter to car stereo.
MaFt |
skipper1 Occasional Visitor
Posted: Mon Feb 26, 2007 5:31 pm Post subject: |
Hi stevejewell. Have you overcome the lack of volume? I am having the same problem. I see people are advising you to plug into the headphone socket. Which is it? My handbook only mentions a microphone jack socket which I assumed only took sound in (i.e.line in) Can it also be used with headphones as a line out?
Are there any electronic experts out there who can advise please? |
Posted: Tue Feb 27, 2007 10:43 am Post subject: |
Not got any further with it, at the moment it is almost useless if on the motorway doing any speed |
Posted: Tue Feb 27, 2007 11:34 am Post subject: |
perhaps This Thread might give you a few clues as to other options on how to increase the colume level available from the device - Mike |
Posted: Wed Feb 28, 2007 4:28 pm Post subject: |
:D Mikes advice at the above thread which leads you to my similar question on the HGV and Motohomes Forum is great. I followed his advice, bought a small fm transmitter and it worked! Problem solved! |
steveg9000 Occasional Visitor
Posted: Tue Mar 20, 2007 4:24 pm Post subject: Garmin Nuvi 360T volume problem |
I am in the process of buying a satnav and had decided upon the Garmin nuvi 360T until I read about the voulme issue. If I use the fm transmitter or fm injection unit workarounds does that mean that I have to have my car stereo tuned just to the satnav or can I still listen to music via the radio or the CD player? If I can does the satnav automatically interrupt the CD?
Steve |
Posted: Tue Mar 20, 2007 8:33 pm Post subject: |
Yes that is a problem you cannot listen to any other channels or CD if you are tuned into the sat nav channel |
Posted: Tue Mar 20, 2007 9:00 pm Post subject: |
you could use the nuvi as an mp3 player which would then pause for directions and speed cam alerts etc
MaFt |
Posted: Tue Mar 20, 2007 11:04 pm Post subject: |
Thanks MaFt. Do you mean still using the fm xm to link it through the car stereo? Would this provide stereo sound quality as I read in one of the reviews for this device that the MP3 player wasn't brilliant quality?
Steve |
Posted: Tue Mar 20, 2007 11:16 pm Post subject: |
the built in mp3 player is very good quality. when i'm using the nuvi i often use the mp3's fed via a 'tape adaptor' to my stereo.
obviously using the fm link the quality is only fm and it'd be better to use a hardwired link to an aux input on the stereo if you have one
MaFt |
Posted: Wed Mar 21, 2007 10:12 am Post subject: |
Thanks MaFt. I have a Volvo with a factory fitted stereo so I'm not sure about an aux input. There doesn't appear to be an option to select such an input on the controls so I suspect there isn't one. I'll ceck with Volvo.
The other option I found last night on the net is a Bluetooth handsfree speaker from Nokia. Presumably I could use that as the nuvi has Bluetooth. It just plugs into the cigarette lighte socket. I guess it depends how loud that is though as some of those units can be a struggle to hear at high speeds.
Steve |
Posted: Wed Mar 21, 2007 10:46 am Post subject: |
steveg9000 wrote: | The other option I found last night on the net is a Bluetooth handsfree speaker from Nokia. Presumably I could use that as the nuvi has Bluetooth. It just plugs into the cigarette lighte socket. I guess it depends how loud that is though as some of those units can be a struggle to hear at high speeds.
bluetooth has certain 'features' within the whole bluetooth protocol such as headset, handsfree, stereo headset, file transfer, object push, basic printing, dial-up networking, serial port and others.
the nuvi only has the 'handsfree' (control phone, make calls etc) and 'object push' (send phonebook entries to nuvi etc) and not the headset required for sending the audio output to a bluetooth stereo.
i'm sure it won't be long until that feature is added as i'm starting to see more stereos with bluetooth built in - all we need is for both the sat nav manufacturers and stereo manufacturers to make sure A2DP is enabled on each (allows the 'broadcast' of stereo sound to be transferred via bluetooth.
MaFt |
