JohnTT Occasional Visitor
Posted: Mon Dec 11, 2006 7:35 am Post subject: Tom Tom ONE USB power feed |
Can anybody please tell me what the pin out and voltage / power requirements are on the Tom Tom ONE mini USB connection?
I intend to buy a cheap car charger to take apart (or PC USB lead) and permanently wire into my car so I don't have an untidy lead dangling about.
There are some cheap ones on ebay which describe themselves as "Tom Tom compatable" and some, more expensive ones, that say "Tom Tom approved". I'm not sure if the mini USB is a universal standard or if Tom Tom have a unique variation on the theme i.e. a different voltage regulated by the cigarette lighter adapter.
I can make my own regulator, if needs be but need to confirm the power feed specification limits. Thanks. |
Andy_P Pocket GPS Moderator
Posted: Mon Dec 11, 2006 3:50 pm Post subject: |
Think THIS PAGE might be what you're after.
YOu definitely do need to have a regulator circuit to reduce the vehicle 12V down to 5V for all TomToms. |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Mon Dec 11, 2006 3:59 pm Post subject: |
you could also plug the tom tom charger into an extension cable and cut of the extension cable plug and then wire that end into the car supply ...thi swill give you the option to remove the tom tom charger cable if necessary.. _________________ *************************** |
Naomi Occasional Visitor
Posted: Mon Dec 11, 2006 4:02 pm Post subject: |
I think this is a related question, rather than the same:
Can the Go/One be charged by using a USB cable to my PC, in the same way that my mobile phone can be charged?
Nao _________________ Too many people "search for the zero inside themselves". Sadly, many fail to find even that.
Nao |
Posted: Mon Dec 11, 2006 4:08 pm Post subject: |
Thanks - of course it's 5V isn't it! I was forgetting the USB cable to PC so the USB interface at the TOM TOM is standard and therefore any generic charger should do. |
Posted: Mon Dec 11, 2006 4:22 pm Post subject: |
I think the other and earlier TOM TOMs are a different power connector so perhaps they don't take charge through their USB... but then again they might. |
Posted: Tue Dec 12, 2006 1:36 pm Post subject: |
You're right...ONLY the One v2 a.k.a "New edition" will charge via USB. |
