Pocket GPS World :: View topic - ppc2002 hardware question
Frosty
PostPosted: Wed Jan 21, 2004 11:20 pm    Post subject: ppc2002 hardware question Reply with quote
hi,
i own a toshiba e310, to my disbelief there is no serial sync cable for it.... is there any way i can connect my etrex vista to it? because when i am driving i find it kinda hard to see the screen on the vista.
frosty
PostPosted: Thu Jan 22, 2004 6:18 am    Post subject: Reply with quote
Nope, you're out of luck. The e310 only sports a USB client connector, not a serial port as would be required for communication with the etrex vista. I'm not sure - maybe there is a USB to serial converter out there...
Frosty
PostPosted: Thu Jan 22, 2004 10:58 am    Post subject: Reply with quote
well i know there are millions of usb-> serial converters.... but theyre usb devices which do it.... tomtom also provides a funny option on their gps host software... "serial on usb" but how do i actually use it for that?
Frosty
PostPosted: Thu Jan 22, 2004 11:00 am    Post subject: Reply with quote
Laughing Out Loud oh yeah btw the e310 does have a serial adapter.... hell its got built in ethernet.... Laughing Out Loud explain the 25 pins in the bottom... eth, usb and serial... and that leaves 6 pins spare ;)
DavidW
PostPosted: Thu Jan 22, 2004 9:29 pm    Post subject: Reply with quote
I don't think there's built in wired Ethernet on the e310 - I'm not aware of any consumer Pocket PC that does have built in wired Ethernet.
Most Toshibas have USB host capabilities, and there's various solutions that procure a serial port via a USB to serial chip (usually the very common Prolific PL-2303 chip).
However, with an e310, I think you're out of luck. I was going to suggest you looked at the web site of the excellent PC Mobile. His Toshiba page is here. If you look at the bottom of the page he says that there's no serial port or USB host capabilities on an e310.
It sounds as if the e310 may join the all the 1900 series iPAQs (apart from the 194x, which has Bluetooth - I think the 1930 may have SDIO, but you've got nowhere to put a memory card if you use a SDIO GPS) in the category of the handful of Pocket PCs that are useless for GPS because you can't connect a receiver. Infrared interfacing is a possibility, and there's at least one homebrew solution, but it's an area laden with problems and the potential market for any commercial interfaces are small.
Frosty
PostPosted: Thu Jan 22, 2004 10:44 pm    Post subject: Reply with quote
is there any way to use a usb -> serial adapter on the end of the cradle cable with a usb gender changer?
DavidW
PostPosted: Fri Jan 23, 2004 4:17 pm    Post subject: Reply with quote
No.
Most Pocket PCs only provide USB client capabilities - that is, they can operate as a USB device where something else is the host (usually a PC to allow USB ActiveSync).
Driving USB peripherals from a Pocket PC requires USB host capabilities - which your Toshiba seems to lack. This is a protocol issue - not simply one of connector gender.
Frosty
PostPosted: Sat Jan 24, 2004 12:39 am    Post subject: Reply with quote
hmmm what if youre using a rom image from an e330? now i know that can handle it and the device is capable of handling it.... as recently tomtom were selling a gps device actually for my pda...
Frosty
PostPosted: Sat Jan 24, 2004 1:30 am    Post subject: Reply with quote
Laughing Out Loud ok well ive found out what i can do... Laughing Out Loud well the e310 can host hardware ;) but due to the fact that the e310 doesnt feed power to the usb device from it's own battery the usb device doesnt power up... i bodged up a cable from a usb cable extenstion and a gender changer and used some power from my usb hub... got a usb -> serial adapter working Smile
22.055 (29 May 24)
