stvme2519 Occasional Visitor
Posted: Fri Oct 20, 2006 11:02 pm Post subject: navman f20 8 digit post code |
ay one got f20 and got full post code to work mine goes red when trying to put last digits in for example b14 4sh wont go in it will on,y let me put in b14 4 if i try put the sh in it wont work
hence making it only 5 digit any one please help |
Tim Buxton Pocket GPS Moderator
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Sat Oct 21, 2006 1:26 am Post subject: |
None of the maps I have, and I have plenty, recognise B14 4SH. I can locate B14 4SB and then nothing until B14 4SJ. I'd suggest that the postcode data itself is out of date. Can you tell us the street you're trying to locate?
I have had a brief play with the F20 and it did support 7 digit (why Navman call it 8 digit I'll never really know!) codes, I'm sure. _________________ Tim |
Posted: Sat Oct 21, 2006 7:54 pm Post subject: |
THAT POST CODE WAS JUST A EXAMPLE MATE I CANT GET LAST TWO LETTERS OF POSTCODE IN ONLY 5 DIGIT NOT 7 DIGIT |
Posted: Sat Oct 21, 2006 8:06 pm Post subject: |
Well then it would have been better if you'd given a working example, not a fictitious one. Also, can you turn your CAPS LOCK off, please? How are you putting the postcode in? Are you tapping Address, Postcode for instance? Are you leaving a space between the two parts? _________________ Tim |
Posted: Sat Oct 21, 2006 8:32 pm Post subject: |
got it sorted sent email to navman replied straight away just go into preferences then system then reset then reset all then when f20 restarts when comes to maps just press blue arrow dont change setting on map and worked so i have full postcode as for postcode it was just example mate so dont take so serious i clearly stated last two letters wouldnt work and i wouldnt use my own postcode ona public forums nor any one elses..so dont be so rude |
Posted: Sat Oct 21, 2006 9:11 pm Post subject: |
Can you tell me in what way you believe I was being rude? _________________ Tim |
paulyoung666 Occasional Visitor
Posted: Wed Nov 08, 2006 11:52 pm Post subject: |
reckon it is best to leave it , $$$$$$$$ alert springs to mind here , there are some ppl you will never be abe to help ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
